Old 03-29-2002, 10:00 AM   #1 (permalink)
alexthegreat2k is an unknown quantity at this point
Guages
Hi, I have just bought and Greddy turbo kit w/intercooler and bov for my 2000 Civic SI. I am about to get it installed, but i want to know what i guages i should get. Also i want to know what psi i could run at with everything in, including the guages.
alexthegreat2k is offline
Old 03-29-2002, 12:09 PM   #2 (permalink)
1Fast GS is an unknown quantity at this point
EGT, AF, FP, BOOST,OIL Press.
Fully Built
LS/VTEC turbo
1Fast GS is offline
Old 03-29-2002, 12:31 PM   #3 (permalink)
Could you go into detail what those do, what they mean, where i could find them? Also by boost, do u mean boost controller?
Old 03-29-2002, 02:17 PM   #4 (permalink)
Car: 92 teg LS
Mods: B16A1
HONDA_LS is an unknown quantity at this point
egt= exhaust gas temp.
af=air fuel
fp=fuel pressure
boost, oil pressure, and all above are just gauges, they pretty much explain themselves
HONDA_LS is offline
Old 03-29-2002, 02:52 PM   #5 (permalink)
When you say boost do u mean boost controller?
Old 03-29-2002, 02:55 PM   #6 (permalink)
Car: 4 paper routes and work at D n B supply
Mods: not enough money to do everything I want to do with it. They say money makes the world go round!
Blaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these parts
Something to contorl the boost.... Some are manual and some are electric which you can adjust from inside the car. Just depends on how much $$$$ you have. Just mu .02 Cents
Blaze
91 Honda CRX DX JDM B20Z
(who knows when I'll install it I have all the parts just need the time!)
www.geocities.com/extremeist45
B and D series Junk for Sale
Dude I smoked your secret stash above your door!
Dude, that was my missletoe.
Oh, It did give me a wired buzz.
Blaze is offline
Old 03-29-2002, 03:10 PM   #7 (permalink)
No a Boost gauge, not boost controller. A boost gauge just tells you the vacuum on one side and how much boost your running on the other side.
Fully Built
LS/VTEC turbo
1Fast GS is offline
Old 03-29-2002, 04:34 PM   #8 (permalink)
Car: '96 GS-R
Mods: See my sig!
Nikolai is an unknown quantity at this point
Most important:
Boost gauge: shows, in kPa, bars, or PSI, how much boost your engine is seeing, so that you don't over-boost and blow an engine.
EGT (exhaust gas temperature): Shows how hot the exhaust gases are that are coming out of your engine. This is much more accurate than an 02 sensor, aka air/fuel ratio sensor (unless you have 800 for a wide-range lambda). Generally, if the temperature goes over 1600F, than you're running too lean.
Normal 02 sensors only provide a significant voltage difference around stoichiometric a/f (14.7/1), so you don't know accurately when your engine is rich/lean.
Wide-range lambda sensors provide a nice linear voltage output vs a/f, so they're the only acceptable sensor if you plan on having an a/f meter, but again, they're VERY expensive.
Other good sensors to have would be:
- fuel pressure (esp. if using a fuel pressure riser for fuel management)
-oil pressure
-oil temperature
Good Luck!
Nick
Nikolai is offline
Old 03-30-2002, 02:26 PM   #9 (permalink)
Car: 96 integra ls
Acman1 is on a distinguished road
if you get the boost controller, will that just take the place of the boost gauge? and also, if you have a wastegate w/ a spring set at 8lbs, can you set the controller to raise the boost to 9lbs? thanks.
no more s14...just an f4i and a "wonderful" 92 izuzu pickup...
Acman1 is offline
Old 03-31-2002, 06:55 PM   #10 (permalink)
Depends if its an internal wastegate or extrenal.
Here are some links to web sites about turbos.
And no it will not take the place of a boost gauge.
www.homemadeturbo.com
www.turbocrx.net
These are great sites for a beginer who is learning about trubos.
Blaze
Blaze is offline
Old 03-31-2002, 07:52 PM   #11 (permalink)
Car: none
SKUNK2import is an unknown quantity at this point
tach GOD IF YOU DONT KNOW WHAT KIND OF GAUGES
YOU DONT NEED THAT CAR OR IT TURBO'D I HATE GUYS THAT HAVE NICE CARS YET DONT KNOW SHIT ABOUT THEM COMMON READ A MAGAZINE PLEASE
stephen
SKUNK2import is offline
Old 04-01-2002, 07:01 AM   #12 (permalink)
Car: 96 integra ls
Re: GOD IF YOU DONT KNOW WHAT KIND OF GAUGES
when u first started off did u know everything...
Acman1 is offline
Old 04-01-2002, 07:08 AM   #13 (permalink)
GunMetal Member
BoostedRex is an unknown quantity at this point
it will take the place of the gauge only if it is the type of controller that has that option built in, not all of them read boost.
and yes you can raise it from 8-9 with a controller, doesn't matter if its a manual controller or electronic, or if the wastegate is internal or external.
BoostedRex is offline
