i did a search and found similar complaints about the ssqv and its flutter characteristic. but i think my situation is unique.
my setup
88 honda crx
-i have a zc motor 1.6l
-garrett TO3 turbo (small)
-im running 5-10psi
-the bov is about 12 inches from the throttle body
-the bov flutters at any boost level, at higher boost it just flutters louder
-i am very aware of the adjuster, and it makes little to no difference
-i have the purple spring/diapham thingy
i have tried these things to solve the problem (none helped)
-tried teeing off the brake booster line
-tried using a biggar sized line (3/8ths + clamps)
-makes the same noise with the vacuum line disconnected
-ive tried about 4 different vacuum sources
-im getting a good vacuum reading (22hg at idle)
i dont even get a little chirp, its just a big loud shutter, or flutter.
it sounds very much like surge, but im not positive.
hks desinged the bov wrong, there never should have been a spring in it.
i took the spring out and sealed it back up. no compressor surge any more, just a nice clean whoosh with an added high pitched whistle.
it sounds like this now
http://alltrac.net/media/HKS-SS.wav high boost
http://alltrac.net/media/hksSSBOV.mp3 low boost
a push type bov relys on vacuum to open up, but it is also opened by the pressure of the boost on the piston.
now... a pull type bov is closed by pressure on the piston, and therefore, when you let off the throttle after in full boost there is extra pressure pushing on the piston, thus making it hard to open as it is. and when you install a spring behind the vacuum diaphram you are adding ADDITIONAL pressure keeping the piston closed.
so the vacuum in the pull type situation has to fight off both boost pressure in the line as well as a spring.
do you know why i know the spring should not be there and the vacuum source is not strong enough in any car to open....the valve should be fully open at idle, because there is no pressure on the piston from boost and there is maximum vacuum right?
wrong, not even idle vacuum is strong enough to open that spring.
do you see what im saying?
but regardless of how my theory works or what you think is normal for this valve, i have why would it chatter and then make a nice clean whoosh with no spring? the chatter noise is either the valve stuck closed and is compressor surge or it is the valve slightly openging and then closing again, also causeing surge.
the fact is, even without the spring it seals under boost and is really responsive.
it also does a real good job of releasing boost in a big burst of air rather than a long chatter noise.
all i know is my bov works great now, and sounds incredible, it sounds like it should
