you are a bit unclear of the concept.
what a VAFC hack is, is using large injectors (larger than stock) (usually 450cc) and scaling back the fuel delivery of the large injectors to flow normal amounts under no boost situations and when you enter boost the large injectors will increase their flow and being that they are quite large they will have enough flow to sustain fuel delivery for the boost level.
if you are using stock injectors you will have to increase the fuel delivery, this will likely limit your boost levels to under 10psi, as will the hack.
stock injectors cannot safely handle 10psi with the amount of timing advance that the vafc introduces.
the way to increase fuel is increase the number in the vafc.
for example, if you want more fuel and its set to 0 across the board, if you set it to 20 across the board you will be getting 20% more fuel.
if you have 450cc injectors in a stock d series typically they are set to -38, this is because the car would not start or run with 450cc injectors because they push too much fuel, so the vafc limits the fuel by 38%.
do more research before you blow your motor.
i would suggest getting large injectors and getting a basemap for the injectors and setup, at least then you will have correct timing and smoother in and out of boost, as well as no cel under deceleration in vacuum.
1988 Honda CRX DX DOHC ZC 1.6L Turbo
13.82 @ 98MPH
fast enough to catch a shooting star!
MY CAR
