Old 07-24-2002, 08:39 AM   #1 (permalink)
96gsrvtech is an unknown quantity at this point
hondata??
yo, im looking into getting a hondata for the drag kit im supposed to be getting, i want to know if any of u guys are using it and do u like it. the one im supposed to get is the stage 3 with the boost option....what else would i need if i buy the hondata to make it work properly, my car is a 96 gsr.....im only going to be boosting like 7psi daily, but im hoping this would make it extra safe and im getting it now so i won't have to worry about getting other fuel related things later, i also have an msd sci...can that be used with Hondata??
96gsrvtech is offline
Old 07-24-2002, 11:17 AM   #2 (permalink)
Well first off what are your goals for the car ?? Yeah the SCI is a good unit. No you don't really need anything to use hondata except to get it tuned. There are other things that you should get like aftermarket plugs and wires. Magnacore and Zex turbo plug are good or stock two staged colder. I'm sure someone will post the part # up for ya... There is a bunch of stuff that would benifit you. Like exhaust, 190 or 255lpm fuel pump, aftermarket suspention, upgraded brakes.
Dr Drew is offline
Old 07-24-2002, 12:41 PM   #3 (permalink)
I ALREADY HAVE THE AFTERMARKET WIRES, SO I HAVE TO GET CERTAIN PLUGS??
Old 07-24-2002, 01:09 PM   #4 (permalink)
Yes, you should use either Zex turbo plugs or the Stock NGK non platnium plugs two heat ranges colder.
Dr Drew is offline
Old 07-27-2002, 06:35 PM   #5 (permalink)
Mods: 12 second all motor integra
C-SPEED is an unknown quantity at this point
No - i disagree. The stock honda ignition is excellent and can easily support up to 300whp. This includes the stock internal coil and wires.
If you raise your compression or run mild boost levels (1-18psi or so) then you only need to get ONE DEGREE colder plugs. I recommend the NGK BKR7E-11. They are a 7 heat range. If you lower the heat range too far, you will have idling and cold start problems.
HTH
Contact mike_sho via pm if you want to advertise your business.
C-SPEED is offline
Old 07-27-2002, 07:30 PM   #6 (permalink)
Car: H22 Accord
DWILSON is an unknown quantity at this point
tach
Arent the 96 tegs OBD II, if so dont forget your wiring conversion. (Hondata is OBD I) Just a thought.
DWILSON is offline
Old 07-28-2002, 04:48 AM   #7 (permalink)
Car: 1999 Acura Integra LS
Yup, wiring harness ~170, from a guy on that other board... HT - search and you will find...hehe I just forgot the guys name
OBD1 ecu too..
skibbs is offline
Old 07-28-2002, 05:25 AM   #8 (permalink)
Car: 1999 Honda S2000
Mods: Straightened exhausts, larger air filter, fuel controller. Port and polish and possible turbo later
Sunder is an unknown quantity at this point
Dr Drew,
Do you know if NGK Iridium plugs have the same problems as Platinum ones?
MY99 S2000
13.9 @ 99mph
When the clutch drops, the BS stops.
Sunder is offline
Old 07-29-2002, 07:14 AM   #9 (permalink)
In light of recent occurances this will be my last week on this site.
If anyone would like to contact me, they can do it via AIM or Email. My AIM SN is PhilanthropistJW and my Email is PhilanthropistJW@yahoo.com. Feel free to to contact me if i'm on or drop me an Email.
Thank you and happy boosting,
Andrew
Dr Drew is offline
