Old 06-02-2002, 09:43 AM   #1 (permalink)
drkn4n is an unknown quantity at this point
how to check if piston rings are fried?
I need to know if there is a way to see if your piston rings are fried ......i have a gsr with 47k miles running at 13lbs of boost and it smokes but i dont know if its just exhaust or oil burning i also have a 3 in exhaust no cat??let me know
99 Gsr
Revhard Stage II turbo kit
Delta Waste Gate
Greddy Type S BOV
Spearco Intercooler
Turbonetics t3t4
Inline Pro Head Gasket
440 cc RC Injectors
Fuel Regulator
Fuel Pump
AFC
Koni Yellows
STR Intake
drkn4n is offline
Old 06-02-2002, 09:48 AM   #2 (permalink)
Car: 98' Integra GSR, 93' Prelude Si
Original_RedGSR is an unknown quantity at this point
Do a compression test. After that, do the test again, but this time add about 1 tablespoon of oil into each cylinder (thru spark plug hole). If the compression increases dramatically, the rings are bad. Be careful not to add too much oil. This would give a "false improvement" to the compression.
RedGSR
Knowledge IS Power
Original_RedGSR is offline
Old 06-02-2002, 10:21 AM   #3 (permalink)
When does it smoke ?? When it is cold, after idleing, driving out of boost, driving under boost, decelerating. Take off your down pipe and see if there is any oil on the the exhaust wheel and down pipe.
Dr Drew is offline
Old 06-02-2002, 11:55 AM   #4 (permalink)
if i am at wide open throttle and i am really hitting it , it will smoke but when i drive it normally its kewl...
99 Gsr
Delta Waste Gate
Greddy Type S BOV
Spearco Intercooler
Turbonetics t3t4
440 cc RC Injectors
Fuel Regulator
Fuel Pump
AFC
Koni Yellows
STR Intake
drkn4n is offline
Old 06-02-2002, 01:09 PM   #5 (permalink)
Car: 1988 honda crx
Mods: T3 turbo 22lbs boost, custom intake/header/exhaust Tec II comp. 65mm throttle body, and a few extra goodies
bmilescrx is an unknown quantity at this point
the oil test will work to a certain degree, your best option is to get a leak down test done, that will pin point your exact problem area, and let you know if its your rings or what. Just about any shop can do one for about $50-100 (depending on shop) and it only takes about 15min.
also have you checked your crank case vent if it is clogged up or not venting, if it is not working properly when you start boosting, the extra blow-by created by the pressure builds up in the crank case and forces oil up past the rings causing your car to smoke while your getting on it, but not smoke while you are crusing.
most likely your problem will be in your rings, and/or crank case vent.
good luck...
Laters...
bmilescrx@yahoo.com
Who said there is no replacement for displacement? Turbo Anyone?
NEW T3/T4 Turbos, wastegates, intercoolers for sale, email me @ bmilescrx@yahoo.com if interested
bmilescrx is offline
