tap into a vacuum line, run it to the map sensor. many people mount it on the firewall, i have mine mounted to the back of my intake manifold. there are 3 wires on the map pigtail that you need to splice and solder to the oem harness map sensor wires. you will probably have to extend them. did you get directions for which wires match to which?
new project- 97 hx vogue silver metallic
b18b turbo
238hp/204tq @10psi
81mm lsvtec
12.54@115.57
newest setup
84mmlsvtec
412whp/300wtq
