Old 06-02-2002, 12:47 AM   #1 (permalink)
GunMetal Member
BoostedRex is an unknown quantity at this point
how to lean out my fuel system???
the only mod i have for my fuelsystem is an fmu, and for some reason when im at idle my car is running really rich, and its pretty rich up until 2psi where the engines combustion can keep up with the fuel delivery.
so how would my car be rich when the fmu only works under boost?
is there some way i can make it leaner, not quite as lean as stock but leaner. without using some sort of aftermarket controller, im just talking about something on the engine i can tune a bit.
mainly because, it has a strong smell and its puffing a bit of black out the exhaust and i have a huge buildup of carbon in my muffler, and i think its wrecking my muffler, changing the sound and just making it look like crap.
so please help me out.
thanx
BoostedRex is offline
Old 06-02-2002, 10:54 AM   #2 (permalink)
If I remember correctly you were running larger injectors than stock. You can either swap out you stock injectors or get a variable FPR and lower your Static fuel pressure well below stock. I'd run the stock injectors.
Dr Drew is offline
Old 06-02-2002, 03:12 PM   #3 (permalink)
Car: 1988 honda crx
Mods: T3 turbo 22lbs boost, custom intake/header/exhaust Tec II comp. 65mm throttle body, and a few extra goodies
bmilescrx is an unknown quantity at this point
on that fmu you should be able to control the static fuel pressure of the rail, however I havent owned a fmu, but ive seen few of them and if i remember correctly you can change the static fuel pressure to the rail, and from that base pressure is were the fmu takes over raising the pressure on its different ratio plates (ie 12:1 14:1) if that dosent work go back to your factory injectors like boostedrex said.
good luck
Laters...
bmilescrx@yahoo.com
Who said there is no replacement for displacement? Turbo Anyone?
NEW T3/T4 Turbos, wastegates, intercoolers for sale, email me @ bmilescrx@yahoo.com if interested
bmilescrx is offline
Old 06-02-2002, 06:09 PM   #4 (permalink)
GunMetal Member
i have stock injectors.... stock everything except for fmu
and my fmu doesn't have ratio diaphrams, it just has a screw type adjuster that raises the ratio and lowers it. and thats the part that the vacuum hooks up to.
Old 06-02-2002, 08:32 PM   #5 (permalink)
Car: 2002 civic si hatchback
themi6group is an unknown quantity at this point
it doesn't sound like it's a rising rate fpr. it's rising the fp even at idle. check all vacuum lines because once i had messed with my cruise control vacuum lines leading to the intake manifold and my car instantly started running rich and smelling at idle. ?
timing is everything
themi6group is offline
Old 06-02-2002, 09:25 PM   #6 (permalink)
Car: 95 civic ex
Mods: a couple ;)
gjcivic is an unknown quantity at this point
what brand of FMU???
jory
gjcivic is offline
Old 06-02-2002, 10:54 PM   #7 (permalink)
GunMetal Member
its an msd one from overboost.com
http://www.overboost.com/obs/product.asp?pid=2628
Old 06-03-2002, 03:25 AM   #8 (permalink)
Car: 1988 honda crx
messed up fpr
if you had a fuel pressure guage it would be alot easier to diagnose your problem, autometer sells a basic fuel pressure guage for about $35-40 or you could get the electric fuel pressure guage for about $90.
With that guage you could see how much pressure is on the rail during any situation. first you would hook up the guage somewhere close to the fuel rail before the pressure regulator.
second start up your car and note the fuel pressure on the guage.
Then remove the vacume line from the pressure regulator and take note of the pressure,(note- your car should hesitate and/or try to die once you remove the vaccume line)
there should be about 10-15lbs difference between the pressures, if there is not your problem may be your pressure regulator, the diaphram may be sticking and not letting the fuel pressure to fall when the car is at idle, causing the car to run rich, but once you start boosting the diaphram works with the added manifold pressure, raising the fuel pressure.
Question - what fuel pump are you running in your car
Other than that I have no idea.
Let me know what happens
Laters...
bmilescrx@yahoo.com
Old 06-03-2002, 11:29 AM   #9 (permalink)
GunMetal Member
Re: messed up fpr
Laters...
bmilescrx@yahoo.com
stock fuel pump..
Old 06-03-2002, 03:58 PM   #10 (permalink)
If everything is stock, find out what your static fuel pressure is.
Dr Drew is offline
Old 06-04-2002, 09:00 PM   #11 (permalink)
Car: 95 civic ex
Mods: a couple ;)
sorry, I didn't even know that MSD made one of those...
That thing is WAY cheaper then the FMU I've seen. Hopefully you can get it to work.
Have you tried contacting MSD, I hear they are a pretty cool company...
Let us all know how that works out, if you get it to work, I might need to get one!
jory
gjcivic is offline
Old 06-04-2002, 09:15 PM   #12 (permalink)
GunMetal Member
it works fine, i just wanna know how to tune it, i think i may end up asking msd themselves, i just thought someone knew.
i recomment this fmu if yer thinking about getting one and have a tight budget, you dont need to change the ratio, very simple.
