I have been talking to some very well known tuners and most tuner don't know much about the f22b2 engines. I have a 1997 Accord LX w/ this motor. This motor is SOHC non vtec. All the tuners said that my power goal will be bery hard to achieve. For some reason deep inside me I still think that it can. Don't ask me why but I really think it can. I see d-series engines get 350HP at like 16-18psi and why can't I get more at the same psi because my engine is bigger correct? The only thing I can see restricting me is my head. I think I can run at least 25psi without lifting my head. Here is my setup and please let me know on what it can do. The motor is built and the turbo is about to be put on. My HP goal is to break 400HP, but now i'm not sure if that can be achieved (all the money I put in to this build seems like a total waste)
SETUP:
Wiseco 85mm Forged Pistons
Crower Billet Rods
CP Piston Rings
ACL bearings
ARP Head Studs
XTD Stage 3 Clutch
XTD 11lb Chromoly Flywheel
Rebuilt Stock Head
(A/C removed, P/S removed, All EGR and Emissions stuff removed)
Holset HY35 Turbo
SPF Manifold
3" Downpipe
3" Straight Piping Side exhaust
2.5" Intercooler Piping
31x11x3 Intercooler
Tial 50mm BOV
Tial 38mm Wastegate
3Bar Map Sensor
550cc RC Injectors (I might need 750cc for the power range)
AEM Fuel Rail
Aeromotive Fuel Pressure Regulator
Stainless Fuel Lines
Greddy Catch Can
P06 Chipped for Uberdata ( might be switching to Crome Pro)
Boost, Oil Pressure, and EGT Gauges
PLEASE LET ME KNOW on what you guys think about this setup, if you suggest anything please let me know. I want to hear your comments about this setup.
