Car: 01 Integra GSR
Mods: Injen cold air,,,AEM cam gear,,,DC 4-1 header,,,tachometer,,,apexi exhaust sytem,,,
install a greddy turbo kit on 01 gsr help
HI, i just bought a greddy turbo here are some question please help me out:
first thing on the box it said 96-99 GSR, will it fit my 01 gsr?
i install most of it allready everthing it bold on now on my car and i mean everything, just alittle bit more and im done, here is the tricky part, i dont know where is the oil feed line of a gsr block, on the greddy install manual it read on the back of the block, i look behind i coundlt figuere it out which one.. and i dotn find how to controll the boost of the greddy turbo any where in the page it is a tdo5 18G turbo, some body told me it is allready preset at 7 psi automaticly work for integra, if you want to turn up the boost and go buy a boost control and turn it up your self, but it is allready at 7 psi, dont know if it is true.... so here again 2 question,
where is the oil feed line on gsr
does the tdo5 18G preset at 7psi
right now everthing is stock onmy motor how much boost i can turn it up or 7 psi is safe...
and how hot can my stock piston can hold up to?? it is 1000-1400 degree ???
please help me the car is very close to finish....... thanks you so much
