Insufficiant Power!?!?
I have come accross a some what mind boggling scenario.
Just turbo charged my pretty much b18 stock block,
Im not sure how much depth i need to go into,
but i seems to be building boost (gauge showing) and have tried few a couple of gauges, however my car is extremly slow.
Ive got a SC61 Turbo with inline pro log manifold, external waste gate, with a dumptube...750 RCs.. etc..
Running Hondata s300 street tuned
Id guess im running around 150-160 WHP, and im running about 10psi of boost, the car seems to be struggling... id imagine looking at post on here i should easily be running around 210-230WHP with my setup...
i just cant seem to work it out... except the turbo may be knackred but there is no play and it seems a relativly new turbo with minmal milage
I would like to mention i had given my head in for some work, 3 angle vlave job and clean etc but nothing major dont see how tht could affect anything .. could be wrong!
Its a b16a1 DOHC vtec engine
Ive done a compression test, and my mechinic has done some kind of boost leak test, however i may need to do one my self.
Ive changed the wastegate spring also incase that was knackred.
I run a 3" DP and exhaust so that wont be restricting.
When im driving the car is deffiantly hesistating, but there are very slight moments when it just feels like going.
I would just like to mention that my car holds the boost absaloutly fine! and the wastegate too
Any advice is more then welcome i am completly out of ideas especially after spending so much $$$
Thanks in ADVANCE
