Old 07-22-2008, 05:56 PM   #1 (permalink)
complexAF1's Avatar
Car: 96 SpEd Turbo Integra (LS)
Mods: Turbocharged LS / Auto - Manual coonversion / etc...
complexAF1 is an unknown quantity at this point
Intermittent Startup Problem
Ok guys, I have searched the many other threads and nothing seems to really fit my problem exactly. I have a fully build turbocharged LS Motor. I am running a MSD 6 with an external blaster coil. I am also using a AEM standalone EMS.
I recently did the head gasket on the car because I was getting some air in the radiator system. When I took the car around the block for a test drive, on only 10 lbs of boost, the timing belt apparently got loose and the car shut off. I also thought that the distributor gear had gotten messed up. I went and ordered one used off of eBay. When it came, the car would not start after resetting the timing belt and changing the dizzy. It was not getting any spark, so the ICM (module) was swapped from the old dizzy into the one that was just installed. It then started up ok. After letting the car run for a while, I shut it off and tried to restart it up; there was only cranking but no starting…there was no spark again. It would then start up after about 20-30 mins of sitting and cooling.
As to troubleshoot, I bypassed the MSD box and ran it directly to the blaster coil. It started up and then did the same thing when it was hot. I also bought a brand new ICM (Module) to see if that was the problem…the same thing. I even put the old dizzy back in the car and it started up and did the same thing…
Any suggestions as to what else I can try.
Thanks in advance
PS: sorry for the long post
The Best Style is your own style...
complexAF1 is offline
Old 07-22-2008, 06:22 PM   #2 (permalink)
g2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphereg2nickle In the rep troposphere
Are you taking the coil out of the dizzy when the msd coil is hooked up? Ive heard that will keep cooking the coil if you dont....
B18 with a B16 head
70mm throttle body-Skunk2 Intake Manifold
1000cc Injectors-Eagle rods-CP 9:1 pistons
ACT 12lb flywheel-ACT 6 puck sprung clutch
Quaife LSD-Full Race Traction Bar
Full Race t3/60-1 turbo kit-Ram Horn Manifold
205/60/14 BF Drag Radials
331HP at 13psi Cams and more boost to come
Currently looking for some ITR or CTR cams, PM me if you have them.
For sale or Trade. Thermal catback 2 1/4" exhaust.
Clutchmasters stage 3 kevlar clutch and pressure plate.
g2nickle is offline
Old 07-22-2008, 06:49 PM   #3 (permalink)
complexAF1's Avatar
To think of it, when i got the second dizzy, the screw for the rotor was tight to get out so I just broke off the tip to get the MSD cap on and hooked the MSD coil wires to the ICM...would the original coil still get a signal and mess things up?
But it also does the same thing when I put the original dizzy back in which was setup properly for the external coil and the intenal coil was removed...
Old 07-23-2008, 09:32 PM   #4 (permalink)
complexAF1's Avatar
Are there any more suggestions?
Old 08-06-2008, 08:39 AM   #5 (permalink)
complexAF1's Avatar
Ok, for those of you with a similar problem, this may help...after trying many different things to solve this issue...the problem has partially been resolved. I changed the MSD external coil, plugs, wires, temperature sensor, dizzy, cap & rotor and I even thought it was my AEM ECU or the program...
It turned out to be that after troubleshooting all of those items and changing out some...I noticed that the TPS sensor on the throttle body was unplugged. This is because I am getting an erratic idle problem and when the TPS is unplugged, the idle smoothes out but revs a little higher. All of a sudden, the motor will not start when it gets hot. All I have to do is plug it back in to start the engine, then unplug it to get the smooth idle again...
only a quick fix; I guess that I will have to replace the TPS sensor, IAC, or MAp sensor...soon to find out
