jdm H22: Turbo or supercharger?? - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Go Back   Honda Forum : Honda and Acura Car Forums > Performance - Tech > Performance Tech > TurboCharger
Old 07-14-2004, 02:42 PM   #1 (permalink)
Car: 1991 Accord
Mods: H22a juiced
4genH22a is an unknown quantity at this point
I heard super chargers are the best way to go on a h22. Someone let me know, and what engine work should i do first(cams,pistons,etc.)?
4genH22a is offline
Old 07-14-2004, 02:43 PM   #2 (permalink)
Cypher Wave
Transparent's Avatar
Car: I dont own a car
Mods: fuck off
Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!Transparent Bow down before me!
what year H22 is it?
Transparent is offline
Old 07-14-2004, 03:08 PM   #3 (permalink)
Car: 93 civic Si
Mods: B16A2 swap, Type R seats
SickRed93Civic is an unknown quantity at this point
in both cases whether it is going to be a super or a turbo charger, you would need to go for mild camshafts and low compression pistons in order to get the best performance out of both. However it is a little bit costy so i would go for direct bolt on super or turbochargers at 7psi it is safer and best specially if it is a daily driven car
personally i would choose turbocharging
It doesn't matter if u win by an inch or a mile winning is winning.
SickRed93Civic is offline
Old 07-14-2004, 03:38 PM   #4 (permalink)
Nas_logic is an unknown quantity at this point
you do know an h22 is one of the worst motors to turbo right? besides that, for get the cams and head for now and build up your bottom end with sleeves, low cr pistons and rods then you wont have to worry about using 12psi...... just a thought. also, i know turbos are bad A$$ but they will be more expensive(good turbo manifold,turbo,etc.) and you wont have to deal with the heat issues. im not saying thats what you should do but, thats what i would use in your case.
Nas_logic is offline
Old 07-14-2004, 11:05 PM   #5 (permalink)
Car: 1991 Accord
Mods: H22a juiced
It's a 2000 jdm h22. I heard that goin turbo was a bad idea on h22's that's why i was thinking a jackson supercharger
4genH22a is offline
Old 07-15-2004, 12:29 AM   #6 (permalink)
Car: 93' Prelude SI
RedlinePrelude will become famous soon enoughRedlinePrelude will become famous soon enough
turbo or supercharger.......if you boost 7psi on either it will tear the engine in the same way, it doesn't matter........7psi is 7psi....or any other psi
h motors need new cast sleeves, forged pistons, and rods...to handle over 8psi safely....you can have the best tunning and crap done to it .....stock block, pistons and rods are stock parts and they just give up and that's it
93' Prelude SI
ENGINE:
-JDM LSD Trans
BODY:
INTERIOR & AUDIO:
RedlinePrelude is offline
Old 07-15-2004, 12:33 AM   #7 (permalink)
Car: 93' Prelude SI
and the other thing is that nobody makes superchargers for 4th gens.....
you could try using one off from a 5th gen prelude(same h22 engine) but you will have to have it custom installed and it's a bitch cause there's not enough clearance by the shock housing where the brackets for the belts are supposed to go
93' Prelude SI
ENGINE:
-JDM LSD Trans
BODY:
INTERIOR & AUDIO:
Old 07-15-2004, 12:38 AM   #8 (permalink)
Car: 93' Prelude SI
another thing is don't worry about the head.......for now at least.....it's not like you're going to build a n/a engine that would be reved higher and then you would need cams ans better springs and headwork stock head is gonna work fine with turbo or supercharger.........the biggest and most important part is to build the block if you know that you're gonna be going over 8-9psi.......and more
if you plan on like boosting 7psi and that's where you gonna leave it...then I would just leave the engine stock and as long as your have it tunnad right it should be ok........but 7psi at the most (on stock engine)
93' Prelude SI
ENGINE:
-JDM LSD Trans
BODY:
INTERIOR & AUDIO:
Old 07-15-2004, 09:10 AM   #9 (permalink)
Car: 1991 Accord
Mods: H22a juiced
Aight, good looking out. The only thing is the H22 isn't in a prelude, it's in a 4th gen. accord, so would it even fit or no??
4genH22a is offline
Old 07-15-2004, 09:23 AM   #10 (permalink)
charliec225 is on a distinguished road
TURBO.
-with pretty low boost and proper tuning, no need to change internals...if you do want to lower compression, like everyone said, you have to also resleeve the block.
-there is no cooling option for supercharged preludes, unless you want to custom make one, so lb for lb, the turbo will give you more power with less parasitic loss.
-also, the costs will be somewhat similar for the jackson racing SC kit or a turbo kit, with the exception that the kit will be made to fit, while the JRSC will have to be modified....
-also, while you can increase supercharger boost by changing a pulley, it just creates more heat which you have no way of dealing with...with a turbo, you can increase boost as needed, so if you want to go back later and beef up the internals, you can just adjust the boost to match
-dont worry about cams unless you get some made for FI. if you're going to modify internals, do it all at once. the head can benefit from a porting and polishing, which can help prevent detonation, but it is not neccessary...just a plus.
basically i see no reason to consider a superchager
charliec225 is offline
Old 07-18-2004, 09:22 PM   #11 (permalink)
Car: 93 ford taurus (sold)/ 88 chevy beretta/ 94 civic cx
Mods: 95 d16z6 swap, CAI, Headers, Exhaust, Venom Control Module, Chipped ECU, 50 Shot....Turbo'd soon...
ginyu6869 ginyu6869 ginyu6869 ginyu6869 ginyu6869 ginyu6869 ginyu6869 ginyu6869 ginyu6869 ginyu6869 ginyu6869
I would go turbo as well..
Originally Posted by yellowrexsi
Try what. Flex pipe from home depot won't work for exaust. You are going throw a code.Stop being an idiot.
ginyu6869 is offline
