Old 11-04-2002, 05:26 AM   #1 (permalink)
steve1178 will become famous soon enough
Knocking
Hi guys,
Just got my car back with the built bottom end but there is a slight knocking comming from the pistons, They are JE pistons 9:1 on a B16a2.
Anyone know if they are supposed to do that and will it stop once it is run in?
Cheers
Steve
steve1178 is offline
Old 11-05-2002, 05:22 AM   #2 (permalink)
Any one with Forged pistons had this??? Please reply!
Old 11-05-2002, 10:51 AM   #3 (permalink)
Car: 2000 Civic EX-T
redfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these parts
If the sound persists when idling, pistons are probably just getting worked in. Don't worry about. If it only comes on when you get on it, well then you may have a problem and I can't really tell you what it is from the description you have given me, you'd have to elaborate.
http://www.londonautoclub.org
Image:
17x7.5 Konig Impact J-Spec;
Performance:
redfox is offline
Old 11-05-2002, 01:27 PM   #4 (permalink)
Hi, Sorry so vague in the description.
yes the knocking is all the time, worse once it has only just been started. its not loud just like a tapet loose but it defanitly is comming from the mid end of the engine.
Im hoping that it will go when it has been run in a bit.
Im not reving the engine past 3k and with 9:1 pistons you can imagine how powerfull that is (Not) , Just got to wait untill i get it tuned untill i can put my foot down, dont want to blow another engine after spending all my money on this one.
The engine management i am getting is a Dastek UniChip, which is fully programable for everything. This is the best i can get in the UK and there is no one over here that has the equipment to program a Hondata.
Booked in on the 2nd of december to have the chip fitted and tuned, so hopfully i will have a 250-280 BHP BEAST
Old 11-05-2002, 04:26 PM   #5 (permalink)
zcsohc is an unknown quantity at this point
You'd wanna be sure to change your oil and oil filter in about 1000kms or so.:eek:
zcsohc is offline
Old 11-06-2002, 04:49 AM   #6 (permalink)
Yea i will change it once i have done the 500 miles, before tuning it. Thanks for the advice.
Old 11-06-2002, 11:15 AM   #7 (permalink)
Car: H22 Accord
DWILSON is an unknown quantity at this point
sounds like normal forged piston slap to me. i wouldnt worry about it.
DWILSON is offline
Old 11-06-2002, 02:16 PM   #8 (permalink)
I'd definitly worry about it. Take it to a few shops in your area and ask them what they think is wrong with it. Then, take it back to the one who did the work if they think it is a bearing and tell them to fix it. Does it get louder when under acceleration ?? It is loudest at first startup because the metal hasn't expanded yet. Take it to get looked at ASAP. And whatever you do, do not accelerate hard when it is knocking.
Dr Drew is offline
Old 11-07-2002, 05:23 AM   #9 (permalink)
I took it back to the person that done it for me and he said that most forged pistons do it, but im not so sure!
When it starts, it is a bit noisy untill all the oil has got around the engine, and when i accelerate you cant hear it so much cos of the sound of the exhaust and stuff.
DWILSON! do normal forged pistons slip all the time?
Old 11-10-2002, 01:32 PM   #10 (permalink)
GunMetal Member
lowpatrol's Avatar
Car: 1994 civic lx
Mods: 1.5with greddy turbo tanabe ex,je pistons crower rods venom 500 cc injectors aem fuel pump and regulater intake and head match ported and polllished motor balanced stage 3 drive shats apexi turbo tmer boost cont. and s-afc msd btm ing.
lowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peonslowpatrol Hello down there miniscule peons
every car with forged pistons has that problem.welcome to th world of forged.
watch who you rev , at red lights. ugly cars can be fast too.
lowpatrol is offline
Old 12-03-2002, 11:04 PM   #11 (permalink)
Car: 87 toy 4wd with chev 350/ 96 accord
Mods: plan to put lude motor in accord
NosmoKing is an unknown quantity at this point
Forged pistons have a looser tolerence when installed because they have a different expansion rate than cast. They are supposed to be a little noisy at start up and use a little more oil than cast, but they should fill up the bore and not knock when hot. How much oil are you using? If its a lot then your tolerances are too open. Contact JE and ask them what to do. Sounds like your shop got sloppy with one of the bores. Make them fix it right. Knocking is distruction; I'd quit running it. :
NosmoKing is offline
Old 12-18-2002, 03:56 PM   #12 (permalink)
OK, I have heard back from the Tuning place and they have said that the person that installed the pistons etc, done the machanical timing wrong (It was 3 teeth out on the cams). :
Could this have been what was causing the knocking???
Still waiting to get my car back..... They are taking foreva, it doesnt look as though i will have it back before xmas now
Please reply,
thanks Guys!
Steve
Old 12-21-2002, 02:38 AM   #13 (permalink)
Three teeth is a hell of a lot. I'm not 100%, but I think that is pretty much collision time.
Dr Drew is offline
Old 12-22-2002, 08:27 PM   #14 (permalink)
Car: 95 Teg
Mods: turbo, and body kit, and a paint job no one has in this world
therumbligteg is an unknown quantity at this point
damm 3 teeth that is like 30 degrees, i never say this kind of stuff and try to be professional but go back to the guy, bitch slap him have him fix it and then bitch slap him again, that is just ridiculous and unacceptable.
Rumble on
therumbligteg is offline
Old 12-23-2002, 10:37 AM   #15 (permalink)
Its kinda sad that we trust people with our cars and all they do is screw you.
Just rang the tuning company again (Sixth time) and suprise suprise the guy who is supposed to be doing it is not there again. Wonder if he will call me back this time...
