Nice writeup...
I'll add a little engineering info...
The ever-lasting post of "what's better: turbo or supercharger" is an interesting topic, because although it is extremely simple in theory, people will continue to argue their side, because they don't understand the operation and the difference between the two...
First, it must be looked at through an engineering standpoint...
Intercoolers are thermodynamic heat exchangers, not fancy articles of style...
They actually DECREASE the amount of work that the engine must produce, (work=power/time) to provide the same level of power without an intercooler.
And work and power are very different values, and have very different units of measurement. (Power=force/time)
Yes, they do this by removing the heat from the charged air, and cooler air is chemically denser than hot air, so it contains more OXYGEN, which creates more power. 5-stage intercooling is common with large power(electricity) production facilities using steam turbines.
And there are FUNDAMENTAL differences in how the two different "chargers" "charge" the air...
It is very important to grasp the concepts of HORSEPOWER and TORQUE, the differences between them, and other basics about Heat Engine Design. Mainly what on earth is Efficiency, Compression Ratio, bore and stroke, etc, etc...
It's even more important to understand what Enthalpy and Entropy are, and how they are used in the design of a thermodynamic heat engine...
If you can grasp those concepts, u will thoroughly understand how and why different engines use different methods of F/I.
In my opinion, as in Engineering Judgement, Turbochargers are the best way to increase power and efficiency of small engines. Regardless, of what someone thinks about "lag" , yes it is physically inherent, but from a purely theoretical view, turbos are more efficient... Mainly because of ONE reason. This is because they obtain the kinetic energy required to spin the compressor and charge the air for FREE, that is, it's redeemed from the exhaust gases, which would otherwise flow freely out of the exhaust...This is the MAIN difference between the two, the other differences are in packaging and how it attaches to the engine.
Yes, an exhaust wheel will slow the exhaust gases going through, but at the same time, an increase in cylinder pressure will offset the loss of power that would be associated with excess "back pressure"...
A turbo blowing the same amount of CFM or M^3/sec (air flow) as a supercharger, will provide more power theoretically, because there is no direct energy loss associated with the turbo, as there would be with the supercharger...
Now, after we determined that a turbo is more efficient, we can look at the reasons why Superchargers were developed...
Superchargers were developed because, while turbos are more effiecient, superchargers come in a smaller overall package, can be literally "bolted" on in place of the Intake Manifold, are cheaper to manufacture, and provide power without having to wait (for a turbine to surpass the surge limit. ie lag).
Superchargers were very popular on radial-piston aircraft engines, and they were used on planes like the B-29 superfortress, to develop 2200 HP from each engine. Not to mention, on V-engines, it's easier to mount a S/C than to run a two-turbo setup.
NOTE : Vortech superchargers and the like, operate like mechanically driven turbochargers (ie non-linear airflow delivery), so they can be compared to both turbos and Roots type superchargers (ie linear airflow delivery), and they have properties associated with the manner in which the charger recieves and provides it's power.
Some of the bad points of a supercharger include:
-Not being able to incorporate an intercooler (be it air/air, air/water, etc)
because the supercharger itself takes the place of the intake manifold, and sends the compressed charge directly through the valves. This leads to higher cylinder temperatures and less power because of the inability of hot air to effectively burn the octane of fuel provided. Now I know Vortech has an "aftercooler" for use with superchargers, but it's still not as efficient as an air/air intercooler traveling at 35mph, and most superchargers do not come with one.
-More mechanical mass, and therefore, more mechanical wear and tear, which leads to shorter life spans if comparable material is used. ( a titanium supercharger would last a LONG time, but be WAY TOO expensive, get it?)
-Constant boost pressure when driving, leading to increased gas mileage and increased wear and tear on engine itself.
-Not being able to instantly change the Pressure Ratio, (must change mechanical drive pulley)
Some good points of a turbo are:
-No parasitic loss of power to drive compressor wheel
-Ability to change boost, by regulating the air flow through a wastegate, at the touch of a finger.
-Ability to use Intercooling to decrease the amount of work that must be done to achieve the same outout, ie HP.
-Ability to drive with low/no boost and preserve gas mileage and reliability
Some of the bad points of a turbo system include:
-Many parts needed to complete turbocharging system (charge pipes, oil lines, coolant lines, wastegate, manifold, etc.)
-Lag, although, if your car is fast enough, it won't matter, cause u could just wait till boost hits, then rip off...Or just turn up boost and call it a day
-more parts that could be damaged, more parts=more probability something breaks or becomes problematic
-Much thought/engineering must be put into designing the cooling and oiling systems because of the extremely high-rpm of turbos.
And just for those who are Hell-bent on proving that superchargers are better, even though they're not, Just take one look at a Mazda RX-7 or a Supra TT from the late 90's, Those companies spent ALOT of money on R&D developing SEQUENTIAL turbo systems, to help eliminate the inherent turbo lag... Why wouldn't they use a supercharger?? Because simply put, it's not as efficient as a properly sized turbo for the intended power band (ie small turbo for low rpms, and big for high respectively).
Hope this helps clarify this age-old comparison.
Later
