Old 05-21-2004, 03:46 PM   #1 (permalink)
soulrider4ever is an unknown quantity at this point
Exclamation List every/all reasons an installed turbo will not boost!
I've lost boost
I have greddy turbo, stock boost, internal wastegate
Here is everything done so far to try and regain boost :
Fixed 2 pre-turbo exhaust leaks and 1 post, replaced gasket.
replaced 2 bolts that came off of exhaust manifold
checked vacuum lines
boost gauge reads vacuum and goes to 0 psi under WOT
BOV gives quiet pssst sound after full WOT to redline
blew air into wastegate and the actuator arm moved to the right
checked for turbo spin and no shaft play - 3 people confirmed OK
replaced old worn couplers from IC couplers with brand new ones
I've taken it to 3 different mechanics, none of them can figure out why I'm not boosting... here is what I'm planning to check for soon.
Things to do :
Blow air into IC pipes and get some soapy water to look for leaks
submerge IC into water with the ends capped
check for a clogged CAT
its your turn to add things to do....
soulrider4ever is offline
Old 05-21-2004, 06:04 PM   #2 (permalink)
Car: Gas Turbine Tech USN
thermalfi'd16 will become famous soon enoughthermalfi'd16 will become famous soon enough
Any hole in the piping. recheck and retighten your clamps.
96 Integra GSR, fully-built JDM B18cR + boost
www.boostfed.com
quality products...great deals...unbeatable customer service!
thermalfi'd16 is offline
Old 05-21-2004, 09:14 PM   #3 (permalink)
b16ahybrid has a spectacular aura aboutb16ahybrid has a spectacular aura aboutb16ahybrid has a spectacular aura about
Seems like the boost monster has been going around and stealing peoples boost lately
94 civic coupe,b16a turbo.
12.42 @118mph...*sold*
b16ahybrid is offline
Old 05-22-2004, 07:23 AM   #4 (permalink)
it's more like the boost gods have opposed me
I got a ? for you guys... on the turbine itself there are 2 wheels, come to think of it, i've only checked the air in wheel or the "compressor wheel" and not the "turbine wheel" . is there a easy way to check to make sure that it is fully functional.. i was under the impression that if one spun the other by default is spinning.
another thing on the to do list eh?
Old 05-22-2004, 07:47 PM   #5 (permalink)
Car: 93' Prelude SI
RedlinePrelude will become famous soon enoughRedlinePrelude will become famous soon enough
if the one in the compressor spins is cause the one in the turbine is spinning it
you have a weird probelem....the only thing i thought of was the connector to the fmic....check your plugs....maybe they don't fire right after the boost starts to build...check your fual pressure too........maybe right after the turbo starts to spin and boost starts to build up one of the things I listed above malfunctions or stops working at all............
93' Prelude SI
ENGINE:
-JDM LSD Trans
BODY:
INTERIOR & AUDIO:
RedlinePrelude is offline
Old 05-23-2004, 09:17 PM   #6 (permalink)
Ok, Today I disconnected the vacuum hose from the internal wastegate to see if I would get infinite boost.. but I didnt get any, so at least I know its not the wastegate opening for some odd reason...
I'm getting more and more positive its a leak in the IC piping, so tomorrow is the official day for leak down test, wish me luck!
Also, is it possible to have 0 psi with a clogged cat? I'm sure I have a somewhat clogged cat, but I wasn't sure if that would actually cause a no boost situation.... get back to me!
PEACE!
Old 05-24-2004, 04:06 PM   #7 (permalink)
Well, todays test was to no avail... IC pipe seem not to be leaking...
Wednsday I remove Intercooler and run a straight pipe to see if its that or not.
Other ideas?
Old 05-24-2004, 04:36 PM   #8 (permalink)
turboakura is an unknown quantity at this point
I helped turbocharged my friends integra and for some reason his car didn't get any boost without the missing link. After it was installed, the car finally started boosting. Check you missing link if you have one. That's the only thing that I can think of.
One question,....when you are at WOT does the motor feel like it is struggling?
turboakura is offline
Old 05-25-2004, 08:50 AM   #9 (permalink)
motor doesnt feel like it is struggling at all... missing link is aok, but i'll double check it... will keep you posted on IC tomorrow..
Old 05-26-2004, 03:12 PM   #10 (permalink)
Car: 2002 VW GTI 20VT
Mods: GIAC, ITG, Bailey, VWms, Ric Gillis, plus some other goodies
4ceFed4_GTI is an unknown quantity at this point
Sounds like a wastegate issue to me. Usually boost leaks will result in reduced boost, not no boost at all. What's your vacuum reading at idle, and what does your boost gauge read as you accelerate?
2002 VW GTI 20VT
14.329 @ 96.18 with a 2.268 60'
My Ride
4ceFed4_GTI is offline
Old 05-26-2004, 04:15 PM   #11 (permalink)
Well, i thought so too, but anyway it reads about 20 VAC at idle and then goes to 0 psi at WOT Will find out tomorrow about the IC, as I was delayed today.. will keep you all posted, thanks for input!
Old 05-27-2004, 01:29 PM   #12 (permalink)
Just removed IC and put a pipe, still no boost...
I'm guessing it is 1 of 2 things...
1) BAD Turbo
2) Wastegate is somehow stuck open even though its in the closed position..
HELP?
Old 05-27-2004, 03:15 PM   #13 (permalink)
Car: 95 GSR
Have you checked you BOV. A faulty seal around the opening in the BOV could let boost out. Do you have a gasket in between the flange and the piping? My buddy had a GReddy Type S. The tension on the BOV was so loose that it was letting boost out. So we tightened it up and boost was there. Another guy had a bad BOV in that the BOV didn't seal up really well onto the flange on the piping.
Check out my old Si-T
uoboarder is offline
Old 05-27-2004, 08:21 PM   #14 (permalink)
Car: 94 INTEGRA GS-R
Mods: H22 at last!!!
slim9300 is on a distinguished road
1) BAD Turbo
HELP?
Are you postive your exhaust manifold isn't leaking? Buy a new exhaust gasket and torque it down to spec, unless you just put in a new gasket. Also, make sure that between the turbo and the manifold is sealing perfectly. Idle the motor and take a can off brake cleaner, spray it all around the seals on exhaust manifold, this helps to identify any leaks. And it wouldn't hurt to try a different boost gauge. If none of this works, just tell me and I will continue down the list of possibilities.
‘95 Integra GS-R Hatch
Engine/tranny: JDM H22A w/ Factory LSD, HCP Mount Kit, Exedy Organic Clutch, Greddy EVO Exhaust, Custom SS Header, AEM SRI, P72 tuned w/ Uberdata, PWR Radiator, Forbidden Motorsports Short Shifter, Trunk mounted Optima Red Top Battery.
Handling/Stopping: Koni Yellow Struts, H&R Springs, Danny Tran Racing Traction Bars, Spoon Rear Strut Bar, ITR Front Strut Bar, Brembo Drilled and Slotted Rotors, Brembo pads, SS Brake Lines, Yokohama ES-100 205/40/17, 17’’ Momo GT2‘s.
Ice/Interior: Alpine CDA-9835 deck, (4) Pioneer 6.5'' 3-way speakers (200 watt), 2001 GSR Full Leather, Autometer Bezel Gauge Pod, Autometer CF Oil Pressure gauge, Autometer CF Air/Fuel Ratio Gauge, Skunk 2 Shift Knob, ITR Shift Boot, etc.
Future Plans: JDM ITR Front End Conversion w/ Gunmetal H.I.D. Headlights, 17’’ Work Emotion Gunmetal Wheels, ITR Spoiler, OEM optional Side Skirts, Shaved side moldings, Kandy Apple Paint.
slim9300 is offline
Old 05-28-2004, 08:13 AM   #15 (permalink)
I'm about ready to sell the whole damn kit and go all motor
the BOV is welded on pretty good, I will double check it though, It still makes a slight Pssst sound though, which led me to believe it is AOK.
BOV picture :
http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
I do have a very small leak by the manifold, It stopped from leaking for a few days, but now it is leaking again.. however I don't think it's that, because even when it wasn't leaking, it still didn't boost, and the compressor wheel spins freely...
I have a question regarding the wastegate though... the is it possible that the actuator arm is holding the flapper to the wastegate closed, but inside its open?
Underhood Picture :
