It's likely that the ACC-1 wire from your timer (usually green wire) isn't hooked up to the correct terminal on your ignition. Does your wiring job look anything like this?
The green one there is what keeps your car running. The red one is a constant 12 volts from the battery, the blue one is unnecessary, it merely allows you to keep power to some other accessory while the timer's running. Hope this helps!
