Old 02-24-2003, 12:16 PM   #1 (permalink)
Lifeless Ninja
civperc's Avatar
edit: some freaky things are happening with the board, I'm trying to fix 'em.
a vbulletin bug or something is causing replies to go to the top of a thread. example: this reply.
Advertise on Superhonda
civperc is offline
Old 02-25-2003, 07:31 AM   #2 (permalink)
Car: 98 acura integra gsr
Mods: crower rods, crower valves, valves springs, retainers,msd 6btm,blaster2 coil,s-afc,apexi turbo timer
14psi is an unknown quantity at this point
WTF is wrong!
i'm tired guys, my car is haveing problems one after another. fix one thing another goes wrong. can never get it right. past two three weeks it was running perfect now all four cylinder is misfireing again. 3000 rpm and under, as i step on the paddle normal feels sort of sluggish just before it gets to 3000rpm it buckles feels like i hit a wall. how would i test my injectors and does the rc injectors go bad quickly. looked for licks can't find but one thing i notices is that the bov doesn't blow off as loud even when i hit it sort of hard when i try to get to 3000rpm without buckleing. this turbo biz is hard work....
14psi is offline
Old 02-25-2003, 07:40 AM   #3 (permalink)
PM-Performance's Avatar
PM-Performance is a splendid one to beholdPM-Performance is a splendid one to beholdPM-Performance is a splendid one to beholdPM-Performance is a splendid one to beholdPM-Performance is a splendid one to beholdPM-Performance is a splendid one to behold
i hear you man i had similar probs for the past 3 weeks , we went nutts trying to figure out what it was, i finally put new plugs in the other night and gapped em tighter and put in a new rotor and boom it runs like a champ again .
sometihng that little can make a huge diff.
what mine was doing it i could hit slight boost fine but when in full boost or close to it , it would pop and feel like it was hitting a brick wall or rev limitier of some sort. . . . . trust me man i know the feeling.
just gotta check all the easy shit 1st. . . . most of the time with that shit its plug related or fuel related.
FORMERLY ITR206
07 Solar Orange 350Z
91 Supra Turbo Targa-
1JZGTE 508WHP and 501tq SOLD
06 Pathfinder
PM-Performance is offline
Old 02-25-2003, 07:58 AM   #4 (permalink)
crdcz03's Avatar
Car: 92Prelude/01S2000
Mods: not stock
crdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peonscrdcz03 Hello down there miniscule peons
whoa that is some freaky shiznit!!
1992 Honda Prelude VTEC -- 2001 Honda S2000
brittany bluegreen metallic -- silverstone metallic
crdcz03 is offline
Old 02-25-2003, 08:04 AM   #5 (permalink)
preciate your opinion and help, clutch and now this. so you replace your rotors what was the milage on your car when you did that. i tried replaceing wires and gapping plugs still the. same problem that you were having. where did you get the new rotors what brand and how much?.. maybe i'll try that.
14psi is offline
Old 02-25-2003, 10:23 AM   #6 (permalink)
try it , it cant hurt, how many miles on the plugs? just get new ones and gap em to like 30 they are like $1.39 a piece and the rotor was $7 from the parts store, for $15 it fixed my prob.
FORMERLY ITR206
06 Pathfinder
Old 02-25-2003, 08:24 PM   #7 (permalink)
Car: 99 GSR
Mods: Turbo, enough said
oneupster is an unknown quantity at this point
This sucks
yup. mine is doing the same thing.
New plugs
New Rotor
New Wires
New Fuel filter
New fuel pump
Replaced Vacuum lines
MAP Sensor is fine
This is driving me up the friggin wall. I cant figure it out. I dont have a fuel pressure gauge so i cant tell if that is what is dropping.
"The things you own end up owning you"
"Pretty happy with where you are in life? Do the contents of your wallet define you? Are you as cool as those dancers on television because you wear the same khakis? If so, keep it up; it seems everything is working out great for you."
"What will you wish that you have don’t before you died? Build a house? Paint a self-portrait? Don’t wait until its too late. Do it now. Otherwise your last thought on this planet will be regret."
"Contrary to what you mothers and teachers tell you, you are not a beautiful and unique snowflake. You are the same decaying organic matter as everything else. We are all part of the same compost heap."
- Tyler Durden. Fight Club
www.oneupster.com
oneupster is offline
Old 02-26-2003, 05:24 AM   #8 (permalink)
Tad
Car: 93 civic HB
Tad is an unknown quantity at this point
hmm, check all ur hoses/lines n stuff,
I know this is a TOTALY different car,
but I had a 3rd gen rx7, and it had a very similar problem,
turned out to be a loose vacuum hose somewhere in the throttle(dont remember exactly)
but urs does sound like somethings loose,
its not getting flow thru the whole system!
-Tad
93 hatch
Tad is offline
Old 02-26-2003, 08:03 AM   #9 (permalink)
well my friend told me it could be injectors not working right, so i will change out my injectors and put my stocks on to see how things go. don't want to purchase new wires, dis-cap and end up being the injectors. since this happen my car been drinking gas like crazy, this morning i put half a tank now it is on empty.. what you think? i sure will check for loose hoses. thanks i hate driving her right now.
14psi is offline
Old 02-26-2003, 08:29 AM   #10 (permalink)
Car: 99 GSR
I was thinking the same thing. I have gone through all the hoses and replaced the ones in question. Vacuum hose is cheap so that was cake.
I also checked the gap on mine just now. 44 was what they were, so i regapped them to 52 (GSR). Its a little better, i see a noticible difference but the problem persists. I have had this happen twice before, and both times it was the plugs. But, that was the first thing i did and it still lingers.
I also though about the injectors, but I dont know where to start there. I am putting in a new manifold this weekend so i wil have them out. I hate this!!!
www.oneupster.com
Old 02-26-2003, 10:20 AM   #11 (permalink)
are you fucking kidding me ?44 and thne gapped to 52? your on crakc man , im sorry to say .
you are losing spark like a mutherfucker, gap em to like 30 maybe 32 tops.
FORMERLY ITR206
06 Pathfinder
Old 02-26-2003, 10:22 AM   #12 (permalink)
Car: 99 GSR
Crakc huh? Whats crakc?
Too hot for me jack ass (since we are insulting each other).
www.oneupster.com
Old 02-26-2003, 12:34 PM   #13 (permalink)
i was kidding. . well not kidding but being excentric. long ass day yesterady and i posted that at like midnight when i got home from school
seriouslt though gap em tighter.
FORMERLY ITR206
06 Pathfinder
Old 02-26-2003, 12:49 PM   #14 (permalink)
Car: 99 GSR
I probably will just because I don’t have jack to loose at this point. It’s just irritating as hell. It’s happened 3 times now....
www.oneupster.com
Old 02-26-2003, 01:02 PM   #15 (permalink)
i know we all go threw this one time or another, it is frustrating when you can't figure it out. i'm going crazy myself. tell me not to go back to all motor cause that is what i am thinking. taking every thing off..since i have a 9:1 compression that might be a good idea?
14psi is offline
