Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda Lifestyle & Entertainment > Home Theater & Electronics
Old 08-02-2007, 12:47 PM   #1 (permalink)
Car: 01 NBP Integra GSR
martinez32 has a spectacular aura aboutmartinez32 has a spectacular aura aboutmartinez32 has a spectacular aura about
PS3: trouble outputing Audio
Let me explain my setup.
tv: Samsung LNS3241D with 2 HDMI, 1 Component, 1 Optical Out
reciever: Sony dvd dream system, supports DTS and DD 5.1, 1 Optical In
games: PS3 and Xbox 360
I have my xbox to tv via component, PS3 to tv via HDMI. Theoretically I should have digital audio from OTA broadcast and the PS3 being sent to the reciever through my optical cable, but still allow analog audio from the xbox go to the reciever. All of that kinda works, digital audio from OTA broadcast go to my reciever, xbox analog goes to the reciever.
The PS3 only outputs Linear PCM 2.1, no DD or DTS 5.1
After reading the PS3's HDMI handshaking compatibility it had lots of problems with older TV's accepting a signal at all, both audio and video. With recent firmware updates that problem should have been fixed, I get video absolutely fine, but digital 5.1 audio is a no show. I tried going into the settings of the PS3 and doing it manually, but to no avail.
Anyone else have this similar problem that can help me out?
edit: the only way I can get DD and DTS 5.1 is if I hook up the optical cable to the PS3 directly, not via HDIM to TV to reciever.
martinez32 is offline
Old 08-09-2007, 04:49 AM   #2 (permalink)
Retired Moderator
05 tC's Avatar
Car: 2005 Scion tC
You might want to post this in the 'Games' forum, lot more traffic over there.
and try giving the_con a PM, he's the resident PS3 expert.
05 tC is offline
Old 08-09-2007, 07:47 PM   #3 (permalink)
Dark Wind
tha_con's Avatar
Car: 1993 Honda Prelude Si (H22a Swap)
Mods: JDM H22a Swap, Greddy SS Header, Greddy SP Cat Back, Car Sound highflow Cat, Skunk2 Cam gears (tuned), Light weight Flywheel, AEM CAI and Short Ram (I switch for different things). ON THE WAY: JUN Valve Train, Jun High Comp Pistons and JUN Flywheel
tha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problemtha_con has a Rep problem
and try giving the_con a PM, he's the resident PS3 groupie.
Fixed for truth.
I'll give it a look man, i'll start doing some research and see what's going on.
But let me get this straight. You've got your PS3 out putting your audio over HDMI, and it's only passing 2.1 LPCM?
tha_con is offline
Old 01-02-2008, 03:42 AM   #4 (permalink)
Car: Accord 2003
Mods: Stock
m39b will become famous soon enoughm39b will become famous soon enough
change the audio settings in the ps3 and make it Linear PCM 5.1
I cried because i had no turbo, till i met the man who had no VTEC.
m39b is offline
Old 01-02-2008, 08:36 AM   #5 (permalink)
j.steimer04's Avatar
Car: 2004 Civic EX 4dr
j.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapy
Wow, never heard of this problem.
EP3's ARE GHEY!!!
j.steimer04 is offline
Old 01-03-2008, 08:02 PM   #6 (permalink)
animosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peonsanimosity Hello down there miniscule peons
i actually had the exact same problem. hdmi is hit and miss really. video was fine through hdmi for me, but never any audio. finally gave up and used component.
you really don't have any options here. sorry bro. either hook the optical up directly. or use component
what's a newb...
animosity is offline
Old 01-04-2008, 08:04 AM   #7 (permalink)
Sounds like this should be covered under warranty, so call Sony, and expect to be without your system for bout a month.
EP3's ARE GHEY!!!
Old 01-31-2008, 03:43 PM   #8 (permalink)
tjones is an unknown quantity at this point
See thats the issue with HDMI 1.2 It sucks! I install Home Theaters for a living and we try to say away from HDMI as much as possible if your using low end components. I'm not saying that your component are low end, but I use $1000 dollar receivers, and they still have issues with HDCP. So I'm not sure what OTA broadcast is but hook up the HDMI to the T.V and the optical to the receiver. You are not gaining anything by going through the tv then the out the tv to the receiver. Don't over think it, thats when you get into trouble.
tjones is offline
Old 01-31-2008, 05:34 PM   #9 (permalink)
Super Moderator
UltraMagneticAL's Avatar
Car: 01 MR-St & 08 M3
i agree w/ tjones...just go hdmi for video and run a separate optical for audio. i probably would only use hdmi for audio if i had a 7.1 system anyways.
Californians: Vote YES on Prop 8! BAN Gay/Lesbian marriage!
Natural Progression...
Nulla tenaci invia est via.
folding@home
UltraMagneticAL is offline
Old 02-11-2008, 07:07 PM   #10 (permalink)
dmb
Premium Member
TMNT JDM
dmb's Avatar
Car: Acura RSX Type S
dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?
forget PCM 5.1, you can't get it by other than going HDMI to a receiver that can handle it (Denon or Pioneer Elite).
You have to do a few things first, and this is something everyone should know.
1. Enable "Bitstream" on output on DVD/BD setup, or else it's pointless.
2. Enable AAC, DTS, and Dolby Digital in your optical audio settings.
3. Save up around 3k for a decent HDMI based reciever, right now all the HDMI based recievers can't handle LinearPCM sound.
dmb is offline
