Old 04-29-2003, 05:15 AM   #1 (permalink)
Retired Moderator
05 tC's Avatar
Car: 2005 Scion tC
B16A breakdown
Orig. writen by pissedoffsol - http://www.hondaswap.com/forums/inde...howtopic=29823
There are 4 general classifications for B16A motors:
B16A SiR
B16A SiR II
B16A2
B16A3
It is often confused as to which motor is which. In this article, we will help you to pick out the clues as to which motor is which, and which one you should get for your B16 swap.
Although I just noted that there are 4 classes of B16A's, we can break that list down into two groups.
Our new grouping of B16A motors:
B16A SiR
B16A SiR II, B16A2, B16A3
Why this breakdown?
It all comes down to OBD. OBD, or on board diagnostics, are broken down into levels, based on the years they are instated. For more info on OBD, please read our article on OBD - Explained.) The B16A SiR, commonly and mistakenly called the B16A1, is an OBD-0 motor. This was the first level of OBD installed on motor ethicals. The other 3 are either OBD-1 or OBD-2 motors.
The SiR was designed for a 4th gen chassis. It works great with an 88-91 civic. However, try putting this motor in a 92+ civic and the problems will just start to flow. The tranny on the SiR is cable. the 5th gen chassis uses hydraulic actuation.
Why is the SiR cheaper?
It's cheaper for several reasons. First, it's older. Second, the A2/A3/SiR II have a higher demand, as they work in newer cars and have a higher output.
How to tell the difference between an SiR and an A2/A3/SiR II
SiR uses a cable tranny- 5th gens are hydraulic
SiR has a lower compression ratio, 10.2:1 and makes 160ps
A2/A3/SiR II have a higher compression ratio at 10.4:1 (10.2:1 A2/A3) and make 160hp (A2/A3) or 170ps (SiR II)
A2/A3/SiR II motors have a better cam profile
A2/A3/SiR II have better oiling functions, keeping things better lubricated
SiR has cast aluminum oil spray bars while the A2/A3/SiR II are made of extruded aluminum.
A2/A3/SiR II have a single- 4-wire O2 sensor instead of 2-single wire O2 sensors
A2/A3/SiR II MAP sensor is an integral part of the throttle body, not an external one with a tube.
A2/A3/SiR II harnesses are grey. SiR has cream colored ones.
SiR is PGM-F1, clearly labeled on the intake manifold, andA2/A3/SiR II are MPFI
SiR valve covers have "DOHC" written in a larger font size than "VTEC"
A2/A3/SiR II valve covers have "VTEC" written in a larger font size than "DOHC"
88-91 B16A's are known as the SIR 1. It uses OBD0 Ecu's, and cable tranny's. The engine serial number is usually 1xxxxxx.
92+ B16A's are known as the SIR 2. It uses OBD1 or OBD2(2b), and hydraulic trannys. The engine serial number is usually 5xxxxxx
The #'s at the end of the block code tell where the engine originated from. The Americas, Europe, Austraillia, etc.....
ALL Japanese engines, generally do NOT have a number after them. (** see below)
SO, if you have a B16A1,2,3,4, or 5. It is usually NOT a true JDM engine. Don't mistake a B16A1 as being a cable unit, because it could be a hydraulic. There are other ways to tell what year it is exactly.
**NOTE: There is ONE exception to this rule. In 90-91, the Civic/CRX SiR came with a B16A1, but they are SUPER rare, and came 160HP with 10.4:1 compression. Their counterpart of the same year was a 158HP, 10.2:1. They are very difficult to tell apart.
05 tC is offline
Old 09-14-2005, 07:09 PM   #2 (permalink)
Car: 95 civic
Mods: b16
ottobong is on a distinguished road
b16a mystery solved
this source is straight from honda japan. the 5th gen civic started in 1991. the b16a with 170ps~168hp motor was also started in 1991. they start the new model line ups the previous yr before it becomes a new model here in the states. look @ 5th and 6th model change both 1991 and 1995. but in the states they were changed 1992 and 1996 respectively.
HONDA - The POWER of Dreams HONDA - The POWER of Dreams
Public information announcement Investor information Company information Customer window
Car Motorcycle General-purpose product Motor sport Community Technology
title Pressroom Press library Press information
title
CIVIC series text genealogy To graphic genealogy
| CIVIC 2DOOR | CIVIC 3DOOR | CIVIC HATCHBACK 3DOOR | CIVIC 4DOOR |
| CIVIC SEDAN | CIVIC FERIO | CIVIC VAN | CIVIC PRO | CIVIC 5DOOR |
| CIVIC COUNTRY | CIVIC SHUTTLE | CIVIC COUPE | BALLADE | CR-X |
| CIVIC TYPE R | CIVIC GX | CIVIC HYBRID |
Year. month Type name Modification item Contents
1979.7 CIVIC HATCHBACK 3DOOR Full model change (2nd) (2nd) super ti Bick 1979.7.18 1979.7.18
1980.6 CIVIC HATCHBACK 3DOOR Minor model change CVCCII engine (1300) 1980.6.10
1980.8 CIVIC HATCHBACK 3DOOR Minor model change CVCCII engine (1500) 1980.7.31
1980.9 CIVIC HATCHBACK 3DOOR Derivation CIVIC HATCHBACK 3DOOR -> CIVIC SEDAN
1980.9 CIVIC HATCHBACK 3DOOR Addition Glass sun roof CX-S
1981.10 CIVIC HATCHBACK 3DOOR Minor model change * Rectangular headlight * grille * bumper
1982.9 CIVIC HATCHBACK 3DOOR Minor model change
1982.9 CIVIC HATCHBACK 3DOOR Addition ES / GL-E
1983.9 CIVIC HATCHBACK 3DOOR Full model change (3rd) (3rd) wander - ti Bick 1983.9.22 1983.9.22
1984.10 CIVIC HATCHBACK 3DOOR Addition Power steering
1984.11 CIVIC HATCHBACK 3DOOR Addition Si 1984.10.24
1985.9 CIVIC HATCHBACK 3DOOR Minor model change * New AT * air dam one bumper
1987.9 CIVIC HATCHBACK 3DOOR Full model change (4th) (4th) gland ti Bick 1987.9.9 1987.9.9
1988.8 CIVIC HATCHBACK 3DOOR Minor model change * ALB
1989.9 CIVIC HATCHBACK 3DOOR Minor model change * LSD * VTEC * engine
1989.9 CIVIC HATCHBACK 3DOOR Addition SiR 1989.9.21
year
1991.9 CIVIC HATCHBACK 3DOOR Full model change (5th) (5th) sport ti Bick 1991.9.10 1991.9.10
1992.9 CIVIC HATCHBACK 3DOOR Addition In ML / ETi AT car
1993.9 CIVIC HATCHBACK 3DOOR Minor model change * New refrigerant * suicide seat SRS
year
1995.9 CIVIC HATCHBACK 3DOOR Full model change (6th) (6th) miracle ti Bick 1995.9.4 1995.9.4
1996.9 CIVIC HATCHBACK 3DOOR Minor model change Safety equipment 1996.9.5
1997.8 CIVIC HATCHBACK 3DOOR Minor model change Safety equipment 1997.8.22
1997.8 CIVIC HATCHBACK 3DOOR Derivation CIVIC HATCHBACK 3DOOR -> CIVIC TYPE R
1998.9 CIVIC HATCHBACK 3DOOR Minor model change * Front and back lamps * bonnet / trunk * front and back bumper 1998.9.3
1999.7 CIVIC HATCHBACK 3DOOR   2000 exhaust emission standards conformity car 1999.7.30
Page top Page top foam/home Foam/home hot news Hot news sight map Sight map searching Searching opinion * thought Opinion * thought
Enterprise activity | Investor information | Hiring information | Inquiry | Concerning private information | Escape item
(C) HONDA Motor CO, the Ltd. and its subsidiaries and affiliates. All rights reserved. HONDA
ottobong is offline
Old 11-01-2005, 02:50 AM   #3 (permalink)
Contender25 can only hope to improve
I noticed that part and had to ask, do you happen to know if they came with a red valve cover instead of black?, but still has the DOHC letters bigger then vtec?.
Contender25 is offline
Old 04-12-2006, 10:05 AM   #4 (permalink)
kbsvtec is an unknown quantity at this point
I know two 89-91 JDM B16A engines, the SiR and the XSi from the Integra 89-91, the diferences are the intake and the gear ratios and i think that the XSi must be 10.2:1 not like the 10.4:1 SiR CR-X or Civic.
kbsvtec is offline
