Old 05-10-2003, 04:10 PM   #1 (permalink)
ALL C5's Avatar
ALL C5 is an unknown quantity at this point
Talking How cams work.
I know we have an open chatter about cams, but i think this is a little more then open chatter, and this way maybe people will read it more.
I just thought since we have an advanced tech and theory forum, I might as well help give as much info. as I can. It may take while for me to write up some more posts, but I will when I have time.
I am going to go over the basics of cams and how they work with your motor.
Three things to look at when buying a cam(s): Duration, lift, and overlap.
Duration- is the number of degrees of the crank rotation that the valve is held open by a cam (don’t forget that the cam spins at half the speed that the crank spins at). A general rule of thumb is that the more duration the cam has, the more top-end power it will create, and this does cause you to lose low-end power. The more duration the cam has the more the valve will stay open during the cranks rotation. The longer the valve stays open the longer the time the cylinder can be filled. This is important at high rpm, since there is less and less time for the cylinder to fill.
Lift- is the height that the valve is lifted of the valve seat. Usually the more lift (with in reason) as the higher the valve is lifted the more flow that can go by. Look at it this way, if you have your window open half way you let in less air then if the window is open ¾ of the way. The draw back to having more lift is that the valve opening and closing speeds become high increasing the chance of valve float. This is why you should upgrade to stiffer valve springs if the cams lift is moderately aggressive.
Overlap- is the point at which both intake valves and exhaust valves are open at the same time (at the end of the exhaust stroke and the beginning of the intake stroke). Overlap is important, because having both intake and exhaust valves open at the same time creates better scavenging of stale exhaust to occur. This is because the flow from the head into the cylinder (from the intake valves) creates a good push to get rid of stale exhaust out of the cylinder. Just like anything though, too much of a good thing is bad. If you get to much overlap the flow from the intake valves will push gas out of the cylinder before it has been used, thus wasting fuel, which equates to power. One more draw back of to much overlap is reversion into the intake ports. Reversion is when fuel/air is pushed back into the intake ports. This reversion causes intake charge dilution at low rpm as the backflow in the intake port gets in the way of cylinder filling. Two things will occur because of this, cylinder pressure becomes poor at low speeds because of the incomplete filling and the fuel/air intake charge becomes diluted because of air rushing back into the intake ports causes low speed misfire. This is why aggressive cams that have big overlapping, create a ruff loopy idle. This misfiring causes the motor to skip a beat in rhythmic fashion at idle and low rpm. Usually firing once every four revolutions when the cylinder gets enough fuel to touch off. This occurrence is called 8-storking, because of the misfiring and the car skipping a beat it fires every other stroke of the 4-stroke cycle.
I hope this helps everybody understand how and what the cam does in the motor.
I will go into detail about other parts in the motor when I get free time.
ALL C5 is offline
Old 05-10-2003, 04:21 PM   #2 (permalink)
Pimpzilla
Danman1116's Avatar
Car: Ford Ranger
Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?Danman1116 you're still here?
Re: How cams work.
thanx bud...learned a lot from that article 2:
Bring on the Sox!
"I once met a young girl filled with fire, That saw through my front to this shell of a man
She knew I'd be a handful from the start, This strong willed woman had an angels heart"
Visit my Mini City -fixed link
Danman1116 is offline
Old 06-01-2004, 07:38 PM   #3 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
http://www.tprmag.com/issue/2/2_camshafts.shtml
kommon_sense is offline
Old 12-05-2005, 10:00 PM   #4 (permalink)
allmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sadallmotorking is sad...just sad
that was sweet man...can i post it on my website?
Join the Rally Revolution!
allmotorking is offline
Old 12-12-2005, 06:49 AM   #5 (permalink)
Cypher Wave
Mods: h23vtec
98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy
here is a write up that i did with info i found from various sites:
1. Max Lift or Nose
2. Flank
3. Opening Clearance Ramp
4. Closing Clearance Ramp
5. Base Circle
6. Exhaust Opening Timing Figure
7. Exhaust Closing Timing Figure
8. Intake Opening Timing Figure
9. Intake Closing Timing Figure
10. Lobe Separation
BTDC means Before Top Dead Center
ABDC means After Bottom Dead Center
BBDC means Before Bottom Dead Center
ATDC means After Top Dead Center
Intake Open BTDC is the number of degrees before top dead center that the intake valve opens on the exhaust stroke.
Intake Close ABDC is the number of degrees after bottom dead center that the intake valve closes on the compression stroke.
Exhaust Open BBDC is the number of degrees before bottom dead center the exhaust valve opens on the power stroke.
Exhaust Close ATDC is the number of degrees after top dead center the exhaust valve closes on the intake stroke.
Duration is the number of degrees the intake valve stays open as measured at .050 inches of lifter lift. This is measured by the degrees that the crankshaft rotates. More degrees of duration will make the engine operate in a higher rpm range.
Exhaust Duration is the number of degrees the exhaust valve stays open as measured at .050 inches of lifter lift.
Overlap is the number of degrees that the exhaust and intake valves are open at the same time
Cam Lift is the distance in inches that the valve is pushed
Advancing/Retarding Cam Timing
Advance
Begins Intake Event Sooner
Open Intake Valve Sooner
Builds More Low-End Torque
Decrease Piston-Intake Valve Clerance
Increase Piston-Exhaust Valve Clerance
Retard
Delays Intake Event Closes Intake
Keeps Intake Valve Open Later
Builds More High-End Power
ncrease Piston-Intake Valve Clerance
Decrease Piston-Exhaust Valve Clerance
Specifics
-A camshaft lobe is an eccentric that converts rotating motion into linear (up and down) movement. To do this, a lobe, or bump, is created from a true circle known as the base circle of the cam - also known as the heel. As the lobe rotates, the lifter follows the rise of the lobe, which moves the lifter upward. The maximum amount of rise is known as lobe lift.
-The maximum lift point on the cam is called the nose, while the inclined areas leading up to and away from the nose are called the ramps.
-Stock camshafts offer relatively short duration and low lift numbers since the factory is after a crisp, smooth idle and excellent part-throttle operation.
-If we increase duration, the intake valve is now open for a longer period of time during the induction cycle. This added duration tends to affect engine power by decreasing idle vacuum and shifting the power curve to a higher rpm. This reduces low-speed throttle response and power while increasing power at the higher engine speeds. Too much duration, especially in stock-type engines, will kill power everywhere, and you will end up with an engine that is extremely lazy.
(All the above taken from Web cams and various sites to save me from spending all night typing it all up )
98vtec is offline
Old 12-12-2005, 04:54 PM   #6 (permalink)
Car: 1996 Honda Civic EX Coupe
Mods: Painted Side Skirts, AEM Intake, Eibach Pro-Kit Springs, A'PEXi World Sport 2 Exhaust, Holley Header. Magnaflow Cat, Si spoiler, JDM Type-R fornt Lip, Spoon Sports Carbon Mirriors, Projector HID Headlights, Integra GS 15" Rims (Gunmetal), BFGoodrich G-Force Sport Tires, Red Wrincle Painted Valve Cover, Others.
rockintheEKoupe is just really nicerockintheEKoupe is just really nicerockintheEKoupe is just really nicerockintheEKoupe is just really nice
Excellent write up. Rep for you!
-96 EK Coupe Lackluster Silver...Shiny, and no longer boring!!! :clap
JDM B16A swap!, A Whole bunch of other money that I wish I didn't spend on a Honda .
-2002 Acura TL: White Diamond Pearl Tricoat
-2005 Acura MDX: Aspen White Pearl Tricoat
FS D16Y8 motor parts. PM me!
SHO fo Sho
rockintheEKoupe is offline
Old 12-15-2005, 11:20 AM   #7 (permalink)
Iron Monk
Car: Acura Integra GSR 97'
Mods: Ebiach 2in drop and black rims
gsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a lifegsrboy171 You need a life
1. Max Lift or Nose
2. Flank
5. Base Circle
10. Lobe Separation
Advance
Retard
Specifics
thats only on a SOHC car, but good shit!!!!!!!
"nobody wants to see naked towel head anyway" -[EK]riMzen[DC5]
gsrboy171 is offline
Old 12-15-2005, 11:21 PM   #8 (permalink)
Cypher Wave
Mods: h23vtec
its for sohc and dohc........its basic camology
98vtec is offline
Old 12-20-2005, 03:52 PM   #9 (permalink)
Bl0wn Z6
ksniperfox's Avatar
Car: 90 rex si
Mods: JR edition GT killer
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
ksniperfox is offline
Old 12-21-2005, 06:11 AM   #10 (permalink)
turbotious kid's Avatar
turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?turbotious kid so um, come here often?
thanks
nice i should read it again. *REP UP*
EG+somegoodstuff=goodtimes ......
http://www.superhonda.com/forum/showthread.php?t=317606 - Bored? join my SHOE Spot thread.
turbotious kid is offline
Old 01-12-2006, 05:16 AM   #11 (permalink)
Car: 2007 Civic Si
Mods: AEM SRI, Skunk2 70mm exhaust
dil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peonsdil2502 Hello down there miniscule peons
thank you for the lesson in camology
2007 Habenero-Red Pearl Civic SI 4dr
193 whp and 141 ftlbs of tq
dil2502 is online now
Old 01-25-2006, 04:37 AM   #12 (permalink)
Premium Member
SuperHonda Premium Member
Car: 04 Solara V6
Mods: Simple. Clean.
accordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a lifeaccordjtstyle You need a life
anyway you could help explain VTC? I have been doing a lot of reading about on in.honda.com (tech help) and even their they dont explain it very well...
any info would be appreciated
2004 Toyota Solara
Click below noobs:
accordjtstyle is offline
Old 09-09-2007, 04:21 PM   #13 (permalink)
Iron Monk
d16y8alltheway's Avatar
Car: 1997 civic ex
Mods: i/h/e/ si tails/02 si wheels/high flow cat/type r headlights/mp3/wma player/
d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?
lol x2 old thread but it's educational.
d16y8alltheway is offline
Old 11-14-2007, 08:23 PM   #14 (permalink)
Car: 1998 BMW 323i
mattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhilemattmcclure Needs to go outside once in awhile
Originally Posted by kommon_sense
