Old 04-30-2003, 10:31 PM   #1 (permalink)
PAC-MAN's Avatar
PAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to do
PISTON/ROD TECH:INSIDE
Piston TECH: I have pics of the B Series pistons, but need to host them 1st. Stay tuned for more Tech.
Stock Piston:
B16A PR3
B16A(JDM) P30
B17A1 P61
B18C1 (USDM) P72-A0
B18C1 (JDM) P72-00
B18C5 (USDM) P73-A0
B18C5 (JDM) P73-00
B16B PCT
B18B1 P75
B18A1 PR4
D15B1 P03
D15B2 P03
D15B7 P03
D15Z1 P07
D16A6 PM6
D16Z6 P28
D16Y7 P2E
D16Y5 P2M
D16Y8 P2P
D17A1 PLM-A0
D17A2 PLR-A0
ZC PM7
Stock Compression:
B16A 10.2:1 (1ST GEN)
B16A 10.4:1 (2ND GEN-UP)
B17A1 9.7:1
B18C1 10.0:1 (USDM)
B18C1 10.6:1
B18C5 10.6:1 (USDM)
B18C5 11.1:1 (JDM)
B16B 10.8:1
B18A1 9.2:1
B18B1 9.2:1
B18B 9.4:1 (JDM)
B20B 8.8:1 (USDM/JDM)
B20Z 9.6:1 (USDM/JDM)
D16A1 9.5:1
D16Z6 9.1:1
D16Y8 9.6:1
ZC 9.5:1
Engine Piston Mixing Compression output:
B16A W/ B16B(PCT) PISTONS YEILD 11.1:1
B16A W/ B18C5 (P73-A0) PISTONS YEILD 10.4:1
B16A W/ B18C5 (P73-00) PISTONS YEILD 10.7:1
SAME ORDER FOR THE REST
B17A1 11.4
B17A1 10.6
B17A1 10.8
B18C1 11.8:1
B18C1 10.9:1
B18C1 11.4:1
Piston/Rod Measurements:
B16A PR3:
ROD LENGTH: 5.290”
STROKE: 3.031”
BORE SIZE: 3.189 “(81MM)
COMPRESSION HEIGHTS: 1.180”
DOME HEIGHT: .098”
WEIGHT: 299 GRAMS
B17A1 P61:
ROD LENGTH: 5.208”
STROKE: 3.205”
BORE SIZE: 3.189” (81MM)
COMPRESSION HEIGHTS: 1.181"
DOME HEIGHT: CAN’T FIND YET
WEIGHT: CAN’T FIND YET
B18A1 PR4:
ROD LENGTH: 5.394”
STROKE: 3.504”
BORE SIZE: 3.189“ (81MM)
DOME HEIGHT: -.055”
WEIGHT: 280 GRAMS
B18C1 P72
ROD LENGTH: 5.429”
STROKE: 3.433”
COMPRESSION HEIGHTS: 1.183”
DOME HEIGHT: .000”
WEIGHT: 305 GRAMS
B18C5 P73-A0
ROD LENGTH: 5.429”
STROKE: 3.433”
COMPRESSION HEIGHTS: 1.190”
DOME HEIGHT: .070”
WEIGHT: 310 GRAMS
B20B
ROD LENGTH: NA
STROKE: NA
BORE SIZE: 3.307” (84MM)
COMPRESSION HEIGHTS: 1.165”
DOME HEIGHT: -.035”
WEIGHT: 312 GRAMS
H22A
ROD LENGTH: 5.63”
STROKE: 3.571”
BORE SIZE: 3.425” (87MM)
COMPRESSION HEIGHTS:1.222"
DOME HEIGHT: NA
WEIGHT: NA
H23A1
ROD LENGTH: 5.571"
STROKE: 3.740"
BORE SIZE: 3.425" (87MM)
COMPRESSION HEIGHTS: 1.203"
DOME HEIGHT:NA
WEIGHT: NA
D15B1/ 2/ 7/ 8
ROD LENGTH: 5.275”
STROKE: 3.326”
BORE SIZE: 2.933” (74.5MM)
COMPRESSION HEIGHTS: 1.208”
DOME HEIGHT: .000”
WEIGHT:
D16Z6
ROD LENGTH: 5.393”
STROKE: 3.543”
BORE SIZE: 2.952” (75MM)
COMPRESSION HEIGHTS: 1.181”
DOME HEIGHT: -.118”
WEIGHT:NA
D15Z1
ROD LENGTH: 5.393”
STROKE: 3.326
COMPRESSION HEIGHTS: 1.092”
DOME HEIGHT: -.277”
WEIGHT:NA
D16Y7
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.130”
WEIGHT:NA
D16Y5
ROD LENGTH: 5.393”
STROKE: 3.543”
COMPRESSION HEIGHTS: 1.161”
DOME HEIGHT: -.106”
WEIGHT:NA
D16Y8
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.083”
WEIGHT:NA
D17A1
ROD LENGTH: 5.511”
STROKE: NA
COMPRESSION HEIGHTS: 1.062”
DOME HEIGHT: -.106”
WEIGHT:NA
D17A2
ROD LENGTH: 5.511”
STROKE: NA
DOME HEIGHT: -.104”
WEIGHT:NA
ROD TECH:
ROD/STROKE RATIO AND ROD LENGTH:
B16A: 1.74/ 134MM
B17A1: 1.62/131.87MM
B18A1: 1.54/ 137MM
B18B: 1.54/137MM
B18C1: 1.58/137.9MM
B18C5: 1.58/137.9MM
B20A3/53RD GEN LUDE) 1.50/142.75MM
B21A1: 1.492/141.7MM
B20B: 1.539/137MM
H22A: 1.577/143MM
H23A1: 1.49/141.5MM
F20C: 1.821/153MM
D17A1: /140MM
D17A2: /140MM
D16Y8: 1.52/137MM
D16Y7: 1.52/137MM
D16Z6: 1.52/137MM
D16A1: 1.52/137MM
D16A6: 1.52/137MM
D15B1: 1.59/134MM
D15B2: 1.59/134MM
D15B7: 1.59/134MM
D15B8: 1.59/134MM
ZC: 1.52/137MM
1995 EJ EX|D16Z6|T3/T04B .48a/r|15.2 psi|Scat Rods|SRP Slugs 9.1:1|Drag Turbo Manifold|Tial 38mm WG|HKS BOV|3" Open DP|uberdata P28|Precision 30" FMIC|ACT S/S Clutch|GE Block gaurd|Greddy Turbo Timer|Other Whips: 1994 Integra LS 1990 Accord Coupe H22A powered
12 sec full interior coupe!
G-Spot Ninja #1
PAC-MAN is offline
Old 05-05-2003, 10:04 PM   #2 (permalink)
PAC-MAN's Avatar
PR3 Pics
B16A 88-91 Piston Pics
G-Spot Ninja #1
PAC-MAN is offline
Old 05-05-2003, 10:05 PM   #3 (permalink)
PAC-MAN's Avatar
P30 Piston Pics
92+ B16A
G-Spot Ninja #1
PAC-MAN is offline
Old 05-05-2003, 10:06 PM   #4 (permalink)
PAC-MAN's Avatar
B16A/ B17A ROD MODIFICATION
G-Spot Ninja #1
PAC-MAN is offline
Old 05-05-2003, 10:09 PM   #5 (permalink)
PAC-MAN's Avatar
P61 B17A Piston Pics
G-Spot Ninja #1
PAC-MAN is offline
Old 05-05-2003, 10:10 PM   #6 (permalink)
PAC-MAN's Avatar
CTR PCT Piston Pics
G-Spot Ninja #1
PAC-MAN is offline
Old 08-04-2007, 03:08 PM   #7 (permalink)
jjtizzle's Avatar
Car: EK4 with B18C4 Swap
Mods: SK2 Intake, Camsgaft, Cam Gears, Fuel Rail, Mugen Head Gasket, RC 310cc Injectors, Exedy cl;utch & Flywheel, Throttle Body, Valves, Springs, Retainers, FPR & Guage, Magna Flow Exhaust 4-1 Mani, SPax Springs,
jjtizzle is an unknown quantity at this point
B18C4
Taken from a Civic VTI 1.8 EDM can u find out the info for that please
jjtizzle is offline
Old 01-17-2008, 07:23 AM   #8 (permalink)
jjtizzle's Avatar
Can i put B18C1 high compression pistons & rods and the crankshaft in the B18C4 which is the EDM version of the GSR. Help Please
jjtizzle is offline
Old 01-17-2008, 10:44 AM   #9 (permalink)
Dark Wind
Snoopy's Avatar
Car: something with wheels
Mods: whole lot of nothing
if a b18c4 is the edm version of the b18c1, why wouldnt the b18c1 rotating assembly fit?
Snoopy is offline
Old 01-24-2008, 04:40 AM   #10 (permalink)
jjtizzle's Avatar
thought the diameters might not match up exactly thats why
jjtizzle is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
