Youll need a long cross tippped screw driver. You can used the regular 6" but a longer one is much easier to use. Say you are trying to remove the driver side light. On the left side of the light there is one screw that you have to get to from behind the center grill. You should see a recess in the grill for the screw driver. Back the screw out and out comes the assy.
2000 Prelude Type SH / JDM Type S Swap / Hondata S100
2008 Honda Ruckus
