ok, so you've got the type r block, so now you need a tranny, like a gsr or type r would be better. then your gonna need a head, you can go with either the b16's(civic si) the b18c1(gsr) or the b18c5(type r) than your gonna need a ecu, axles, upgrade the brakes, and the shiftlinkage cables like you already mentioned. well theres probably a couple things i left out. so heres a website to help you out.
http://hondaswap.com/
