Start off with 600 (dry) sandpaper on an Electric Palm/Finishing Sander or Sanding Block.* Sand to a smooth surface. i did this step over and over before moving on to step 2. cuz my valve cover is dirty as shit. if yours are like mine, i suggest you do this step long than others.
Step 2
Cut 1000, 1500, and 2000 grit (wet/dry) sandpaper into 1-2" squares.* Then soak in a bowl of water.* Bowl should be one you care a little about.
Step 3
Sand surface with wet sandpaper using varying circular motions.* Sandpaper will slowly loose its grit as time goes on.* Use 1000 (1st), 1500 (2nd), and 2000 (3rd).
Surface will get smoother as time goes on.* Clean cover/area thoroughly.
Step 4
Use a polishing agent to finish surface area.* use NeverDull, Bue Magic Metal Polish, but any polish will work when used as directed.
Your Done!!! Enjoy your new Polished Valve Covers!
__________________ "Your Mind is your first enemy."
Mods: skunk 2 coil overs, skunk 2 strut tower braces, skunk 2 short throw shifter, reactive intake, greddy cat back exhaust, rims with 205/40/17's, pioneer/alpine audio
there really is no point in going higher than 1000 grit paper. the way i do it is:
1) wet sand everything starting with about 150 grit then work your way up going to 220, 400, 600, and finally 800. only use the black sandpaper because its the only kind that can hold up to wet sanding.
be careful not to sand in one small area too long or you'll have a wavy finish. you really wanna change directions with the sandpaper as much as posible because it helps get out the scratches easier and keeps it from getting wavy. dont cut corners here, any scratches will show.
2) get a buffing wheel and some rubbing compound. you can buy a buffing kit at sears or home depot that can fit on your drill and comes with the compounds and everything. there should be 3 sticks, a really dark brownish blackish one, a lighter brown one, and a white one. i usually just use the lighter brown one.
buff the aluminum untill its shiny but dont rev it too high or stay in one spot too long because the compound will burn. you dont have to go too nuts, it polishes pretty easy. after this, clean the compound off with a rag. any solvents will dull it so its best to just rub it off.
3) polish it using mothers billet aluminum polish. its a cream that comes in a little jar and you can get it from autozone. it says BILLET right on the front of the jar, you'll know it when you see it. best shit i have found as of yet. just follow the directions on the jar, its easy. use a soft cloth to buff it.
this should cost you about 15 to 20 bucks to do and it will take a little while by hand, expecially around raised lettering. probably a good 2-3 hours of sanding to get it perfect if you have raised lettering like the vtec emblem. once its all sanded, it will take about 20 minutes to buff it, max.
good luck! once you're done, it will look like chrome if you did it right.
youd be surprised how popular a lot of things are. the market for sleeper products is huge since most states treat you like a jew in 1943 poland if youre a ricer
Originally Posted by Elegant Runaway
i chrome my valve cover out like last year, and still is chrome til this day.
both method works, but 2000grit is just for a smoother touch.
after polishing a few motorcycle frames and a bunch of other shit, i have found that there is no need for anything over 800 grit as long as you dont take any shortcuts. you will have the same results as if you went all the way to 2000 grit.
well i havent polished my valve cover yet because frankly my car isnt worth maintaining it but here's my current motorcycle's frame. the polish job is about 1 year old. i polish it every month or so lightly with mother's billet polish. i started with 150 grit because it was a really rough sandcast finish and finished with 800 grit. picture isnt the best, ill try and take another
oh and here's the before. ignore the big dummy in the middle.
also, i forgot to mention.... heavy duty easy off oven cleaner takes off the anodizing on aluminum. be sure to take off the anodizing before sanding because its pretty tuff shit. just spray it on for about 30 minutes and when it turns black then just rinse or wipe it off
