Old 10-19-2003, 12:06 AM   #1 (permalink)
Mods: fram air filter!!! haha
AccOrDZteCh is on a distinguished road
cleaning out the IAC
tools:
13 mm wrench
throttle body cleaner thats safe for sensors (sea foam i use)
q tips
TIme required: 30 minutes
diffuculty: (1-10) 3...
you should clean your throttle body too. since thats apart of the intake system.
why you should do this?
the reason as to why you should do this is simple. over time the air filter lets in particles that builds up. all that stuff gets on the sensors and then kills a little MPG and performance. might as well clean it out...i noticed a increase in throttle response, and smoother engine performance.
procedure:
1. locate the IAC and remove the 2 gold 13mm bolts...(PIC # 1 & #2)
2. pull off the IAC...and DO NOT REMOVE THE RUBBER LINES UNDER.
3. get your throttle body cleaner and put the straw on and spray the screen. (dont spray too much just 2 shots).
4. use the qtip and gently wipe away the black guew....use another one when it gets black.
5. use a flathead screwdriver and gently edge the screen to get the surrounding gunk off.
6. the screen should be pretty silver
7. spray some throttle body cleaner into the holes that go into the IAC...let evaporate for 10 minutes
8. clean the rubber ring with a rag and replace the IAC
9. when u start the car make sure that u revv the car to get the carbon buildup out that the throttle body cleaner took out.
you should notice a differnce in driveability. for a while, push the car to its limit to get carbon out...
***problems?***
if u notice a low idle, u may have taken off the conenctor on the IAC (the black thing).
if ur car idles abnormally, the IAC is still wet...revv revv revv...let idle to dry or turn off and let dry....it shouldnt be like that for long.
adjust idle as well. then go ahead and reset ur ecu.
note: you can buy sea foam only in certain places....i got mine at napa i believe, or at tognotties. but any that is safe for throttle bodies and sensors is fine....
u can also spray a little cleaner into the PCV valve....
got gas?
stock 91 honda accord ex 142k
all sho..
my car pics
aww, she is smiling at you.
mods:
f22a6 intake manifold swap
DRL custom..
catch can-comming
CAI-custom and done.
strut bar front upper rear lower tie
AccOrDZteCh is offline
Old 09-06-2007, 11:32 AM   #2 (permalink)
spider210 is an unknown quantity at this point
where would this be located on a 00 ex vtec y8 engine? pics would be very helpful
spider210 is offline
Old 10-08-2007, 10:26 AM   #3 (permalink)
Iron Monk
d16y8alltheway's Avatar
Car: 1997 civic ex
Mods: i/h/e/ si tails/02 si wheels/high flow cat/type r headlights/mp3/wma player/
d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?
werd.
d16y8alltheway is offline
Old 11-08-2007, 08:09 PM   #4 (permalink)
MegaMax's Avatar
Car: 2006 Honda Pilot & 1992 Honda Civic
MegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriendMegaMax Needs a boyfriend/girlfriend
Pictures...
I'm going crazy here... I found this DIY with Pics and nicely written up (not that this isn't) but I can't find it now..
If anyone has that thread please link it to this one.
EL DON COLOMBIANO
WTB: LS Mesh Rims...
MegaMax is offline
Old 11-08-2007, 09:08 PM   #5 (permalink)
MegaMax's Avatar
tech wrench Found it...
Goota Love Google..!
http://www.honda-tech.com/zerothread?id=1575913&page=1
EL DON COLOMBIANO
MegaMax is offline
