DIY cleaning your IACV - Honda Forum : Honda and Acura Car Forums
Go Back   Honda Forum : Honda and Acura Car Forums > Performance - Tech > DIY: Forum
Old 01-17-2004, 10:59 AM   #1 (permalink)
Car: 94 ETC, 1988 RX7 10thAE, 1992 DA integra
Mods: Axxis pads, brembo rotors, JDM one pieces
capn will become famous soon enough
Hey all
for those of you that have an irradic idle and are annoyed with it heres how you clean and fix the problem.
IACV = Idle Air Control Valve
step one: locate your IACV it looks like this and on D series engines its mounted on the rear of the intake manifold near the throttle body, and on F series engines its mounuted towards the front of the car on the intake manifold near the throttle body.
Step two: remove it, all you need to do is take the 2, 12mm bolts out, disconnect the electrical connection, and your heater lines that run to it. (note put a rag on the heater lines so it doesnt spill everywhere)
Step three: take some brake cleaner or carb cleaner and spray out the screen, which as you can see is very clogged on my 180K+ D15b8.
NOTE you can also take off the bottum part and inspect the gasket to make sure its clean and dirt free, and in my case it was
Step four: Let it dry, then reconnect your electrical connection, your heater lines, and your bolts and BAM your done.
Hope this helps some of the noobs out there
capn
I am not young enough to know everything yet.
capn is offline
Old 01-18-2004, 06:53 PM   #2 (permalink)
Girl is on a distinguished road
Is it the same on the D16y8?
Do I have to remove the IM or TB to reach it?
Girl is offline
Old 01-19-2004, 08:17 AM   #3 (permalink)
i did this with my engine removed but i dont think you should have to but, im assuming all D series will be the same
capn is offline
Old 01-19-2004, 11:13 PM   #4 (permalink)
Mods: fram air filter!!! haha
AccOrDZteCh is on a distinguished road
nice, i have a DIY for the 4th gen and 5th gen accords...just to let people know.
good writeup..
got gas?
stock 91 honda accord ex 142k
all sho..
my car pics
aww, she is smiling at you.
mods:
f22a6 intake manifold swap
DRL custom..
catch can-comming
CAI-custom and done.
strut bar front upper rear lower tie
AccOrDZteCh is offline
Old 01-20-2004, 11:25 AM   #5 (permalink)
theforeman is on a distinguished road
good writeup..
car to post pics
cuz my car has a weird idle sometimes, almost like there is a vaccum line d/c. and my idle sits high then drops occasionally. then goes back up. and then sometimes its fine.
theforeman is offline
Old 01-20-2004, 01:49 PM   #6 (permalink)
Originally posted by theforeman
car to post pics
what series engine do you have?
capn is offline
Old 01-20-2004, 02:33 PM   #7 (permalink)
Dark Wind
Shifty_56's Avatar
Car: Combat Boots
Shifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problemShifty_56 has a Rep problem
yea my piece of shit sedan does that to, but it seems like when i get on the gas, it likes to stumble. i changed the plugs and distributor cap, with no results, so looks like im going to the store to buy some cleaner
Shifty_56 is offline
Old 01-20-2004, 03:23 PM   #8 (permalink)
car to post pics
cleaning out the IAC
tada...
got gas?
all sho..
my car pics
mods:
DRL custom..
catch can-comming
Old 01-20-2004, 05:08 PM   #9 (permalink)
f22b1
and thanks for the posts accordztech
is that diy i sent ya working at all.
Old 01-20-2004, 05:21 PM   #10 (permalink)
f22b1
ok thats the same engine my friend had and we did it, and accordztech shows you where it is its the same procedure as i showerd you
capn is offline
Old 01-21-2004, 09:24 PM   #11 (permalink)
i do it every 3k...it takes like 20 minutes...good luck dudes and good writeup
got gas?
all sho..
my car pics
mods:
DRL custom..
catch can-comming
Old 01-22-2004, 02:41 PM   #12 (permalink)
... good writeup
thank ya
capn is offline
Old 10-30-2004, 05:37 PM   #13 (permalink)
Car: 92 EG Hatch
Mods: AEM cold air intake, full 2,1/4" exhaust piping, Apexi N1 style carbon wraped muffler, Racer Design coilover suspension, 17" Motegi white wheels.
EGoutlaw is an unknown quantity at this point
Thumbs up
Thanx for the info. I did that in 5 min. Works great, Thanx again.
EGoutlaw is offline
Old 10-30-2004, 09:54 PM   #14 (permalink)
no prob im glad to see my DIY Threads are still a use to everyone, and i havent been on here in like a year, ever since i crashed the little civic
capn is offline
Old 11-08-2004, 07:07 AM   #15 (permalink)
GunMetal Member
UMREX is an unknown quantity at this point
i just did this on my 91 crx si. the 2 hoses attached to this thing were a bitch to get off after i removed the clamps, so i cut them. the hoses are long enough so you can still reconnect them to the valve no problem. just cut off a little though. i used simple green to clean it and it work wonders. good diy info.
UMREX is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Powered by vBulletin®. Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
