12-07-2003, 01:25 AM
#1 (permalink)
Gaijin
Car: '94 Integra Ls/vtec-Turbo, '93 R33 Skyline GTS-25t
Mods: Never enough...
DIY distributor CAP & ROTOR replacement
The distributor's cap and rotor need to be replaced when the rotor and terminals in the cap have become worn/corroded and prevent enough electric charge to pass trough the spark plug wires to the spark plugs (you can brush the corrosion off with a wirebrush). This preventive maintenance will improve combustion and help your car feel "smoother" among other things. Note: the following procedure was performed on a 3rd gen integra but it will be similar on other hondas.
Materials: new cap and rotor from your local auto parts store (the cap normally comes with new retaining screws and a new seal, if it doesn't use your old ones).
Tools needed: phillips screwdriver, 8mm wrench, 10mm wrench, pliers(may not need this).
Step 1: This is not really necesary but to be safe I like to disconnect the battery, plus it resets your ECU. Use your 10mm wrench to losen the battery terminals (negative then positive) and disconnect them.
Step 2: Unplug the spark plug wires from the cylinder head (NOT the distributor!)
Step 3: Proceed to remove the distributor cap by unscrewing the retaining bolts with your phillips screwdriver.....
....or you can also use the 8mm wrench.
The lower bolt is kind of hard to get to so I took my intake tube off, this also gives you more room to work with.
After removing the cap you will see the ROTOR
Step 4: Under the rotor there is a screw, remove it (rotor has to be in a certain position to do this)....
....or if the rotor didn't "land" on the right position to unscrew it, or if you're like me and stripped it, brake the rotor off with some pliers, then you can get to the screw by removing the little cover with the spring, make sure you replace the cover afterwards.
I had to use a needle nose to loosen the stripped screw.
12-07-2003, 01:27 AM
#2 (permalink)
Gaijin
Step 5: Remove the rotor (or what's left of it) from the distributor shaft.
Step 6: Install new rotor, don't worry about messing up, it can only go in one way.
Step 7: Reinstall rotor screw.
NOTE: If you stripped your screw you're gonna have to improvise until you can get a replacement one. I used one of the new screws that came with the new cap (luckily it had the same threading), although is twice the lenght its working fine so far but I wouldn't recommend it, I don't know what can happen.
Step 8: Remove the old seal and replace with the new one.
Here is a comparison of the two caps, notice the worn terminals on the old cap.
Step 9: Relocate the spark plug wires on the new cap one by one in the same order as the old cap. These wires need to go in a specific sequence so if you removed them and don't know where they go refer to the picture below for the correct order. The correct firing order is 1-3-4-2 so starting clockwise from the bottom left of the cap is 1. On a SOHC motor the #1 is at the top left, same firing order.
Step 10: Install the new cap (tighten the screws hand tight, you don't want the plastic to break, but not loose either).
Step 11: Replace the spark plug wires on the engine. Here is the firing order for reference.
Step 12: Reinstall the battery cables (positive then negative), and all other equipment you may have taken off.
Step 13: Start your car and let it idle for a few minutes.
~THE END~
12-07-2003, 09:22 AM
#3 (permalink)
Car: 1996 Civic HX
Mods: TBD
D16Y5
Do you know anyone or have you seen any articles regarding engine swaps (i.e. B18C, D16Y8) for a D165? Mine has exceeded its predicted Mean-Time-Failure rate. I am using too much damn oil and I want a higher performing engine.
12-07-2003, 01:02 PM
#4 (permalink)
Gaijin
Re: D16Y5
Please keep it on topic, this is the wrong forum to ask that question but I'll help you anyway. Go to the HYBRID/JDM forum in here, it should have what you need to know about that. Here is a start:
Putting engine x in car y...
06-19-2005, 05:43 AM
#5 (permalink)
as a note to that if the rotor screw doesnt land in the right position turn key for one second then turn it off untill its in hte right position
So Fresh and so Clean Clean
06-19-2005, 04:19 PM
#6 (permalink)
Gaijin
You can do that if you want but it'll take you hours to get it right... why do that when you could just break the rotor off? you're gonna replace it anyway. Another less simple way of doing this is by turning the crank until it lines up right but I don't recommend it.
07-10-2005, 08:00 PM
#7 (permalink)
Car: 97 Honda Prelude
Mods: Wings West Body kit, AEM cold air intake, DC Sports 4;2;1 Header, B&M shifter, 17" ENKEI wheels, KYB struts, Neuspeed Springs, Street Glow Underbody neons, Int. neons, 7" TV screen, PS2, Tenzo R Racing seats, Alpine CD player, 12" kicker subs etc.
where can i find the internal distributor seal im having trouble. the seal that the shaft slides through?
07-11-2005, 09:02 PM
#8 (permalink)
Car: 99 Prelude Type SH, 83 RX7 GSL
I just replaced mine the other weekend. My screw was stripped so that was a major bitch, but other then that it's totally easy, pretty much self explanitory.
PFC USAR - Light Weight Vehicle Mechanic
83 RX7 GSL: LS1 and other go fast goodies
99 CMB Prelude Type-SH:
Type-s swapped, type-s front lip, type-s front strut bar, progress adjustable rear sway bar, jdm fogs, mugen exhaust, SRI, mugen coilovers, mugen thermopak, competition clutch(stage 3)/flywheel, hawk HP+ brake pads, CF hood/trunk... and more to come.
Autocross is for drivers.
Drag racing is for cars.
Prelude FAQ
07-11-2005, 10:51 PM
#9 (permalink)
Car: 1995 Nissan 240sx
Mods: Circuit Sports Exhaust/5 lug hubs/RUCA/front strut tower bar/V2 Short Shifter, Stance GR+, Techno Toy Tuning Subframe Collars/TC Rod, Welded Diff, Z33 Inner/SPL v5 outter Tie Rod, White line rear sway bar, 5spd conversion
red X owns you. fix and i shill delete my post
edit: if you know where i am from...[OT SHO]
you'll learn not to do so
07-11-2005, 11:05 PM
#10 (permalink)
If your'e inclined enough... on the Red X, right click, go to properties, then copy the url, past it into your address, and go. The picture should be there.
Prelude FAQ
09-28-2006, 09:51 PM
#11 (permalink)
About the Rotor not being in the proper position, I got this tip from D-series.org
"If you cannot see the screw, feel for it and find out where it is. Put the car into gear and rock it back and forth. You will notice the rotor start to move. Do this until you see the screw. This is faster than turning the crank."
Anyone try this yet?
09-29-2006, 05:52 AM
#12 (permalink)
Gaijin
Damn that was a long time ago when SHO didn't have image hosting, so the pics are with imagestation, I haven't used imagestation in years and I'm surprised those pics still work...
On a side note, the pictures are working so STFU
09-29-2006, 05:55 AM
#13 (permalink)
Gaijin
Is it really that hard to just brake the old rotor off?
