DIY distributor CAP & ROTOR replacement - Honda Forum : Honda and Acura Car Forums
Go Back   Honda Forum : Honda and Acura Car Forums > Performance - Tech > DIY: Forum
Old 12-07-2003, 01:25 AM   #1 (permalink)
Cautela's Avatar
Car: '94 Integra Ls/vtec-Turbo (now GSR proj), '93 R33 Skyline GTS-25t (Sold), '04 RSX Type-S (new whip)
Mods: Never enough...
Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?Cautela Why haven't you checked into rep rehab yet?
The distributor's cap and rotor need to be replaced when the rotor and terminals in the cap have become worn/corroded and prevent enough electric charge to pass trough the spark plug wires to the spark plugs (you can brush the corrosion off with a wirebrush). This preventive maintenance will improve combustion and help your car feel "smoother" among other things. Note: the following procedure was performed on a 3rd gen integra but it will be similar on other hondas.
Materials: new cap and rotor from your local auto parts store (the cap normally comes with new retaining screws and a new seal, if it doesn't use your old ones).
Tools needed: phillips screwdriver, 8mm wrench, 10mm wrench, pliers(may not need this).
Step 1: This is not really necesary but to be safe I like to disconnect the battery, plus it resets your ECU. Use your 10mm wrench to losen the battery terminals (negative then positive) and disconnect them.
Step 2: Unplug the spark plug wires from the cylinder head (NOT the distributor!)
Step 3: Proceed to remove the distributor cap by unscrewing the retaining bolts with your phillips screwdriver.....
....or you can also use the 8mm wrench.
The lower bolt is kind of hard to get to so I took my intake tube off, this also gives you more room to work with.
After removing the cap you will see the ROTOR
Step 4: Under the rotor there is a screw, remove it (rotor has to be in a certain position to do this)....
....or if the rotor didn't "land" on the right position to unscrew it, or if you're like me and stripped it, brake the rotor off with some pliers, then you can get to the screw by removing the little cover with the spring, make sure you replace the cover afterwards.
I had to use a needle nose to loosen the stripped screw.
"Look out", gaijin with スカイライン
αθεος
Helpful threads: DIY distributor cap/rotor replacement | Got idle problems? CLICK HERE | Honda OBD1 ECU pinouts
Videos: Okinawa undergound racing | Skyline+full exhaust+tunnel
Cautela is offline
Old 12-07-2003, 01:27 AM   #2 (permalink)
Cautela's Avatar
Step 5: Remove the rotor (or what's left of it) from the distributor shaft.
Step 6: Install new rotor, don't worry about messing up, it can only go in one way.
Step 7: Reinstall rotor screw.
NOTE: If you stripped your screw you're gonna have to improvise until you can get a replacement one. I used one of the new screws that came with the new cap (luckily it had the same threading), although is twice the lenght its working fine so far but I wouldn't recommend it, I don't know what can happen.
Step 8: Remove the old seal and replace with the new one.
Here is a comparison of the two caps, notice the worn terminals on the old cap.
Step 9: Relocate the spark plug wires on the new cap one by one in the same order as the old cap. These wires need to go in a specific sequence so if you removed them and don't know where they go refer to the picture below for the correct order. The correct firing order is 1-3-4-2 so starting clockwise from the bottom left of the cap is 1. On a SOHC motor the #1 is at the top left, same firing order.
Step 10: Install the new cap (tighten the screws hand tight, you don't want the plastic to break, but not loose either).
Step 11: Replace the spark plug wires on the engine. Here is the firing order for reference.
Step 12: Reinstall the battery cables (positive then negative), and all other equipment you may have taken off.
Step 13: Start your car and let it idle for a few minutes.
~THE END~
αθεος
Cautela is offline
Old 12-07-2003, 09:22 AM   #3 (permalink)
Car: 1996 Civic HX
Mods: TBD
radicalrider is an unknown quantity at this point
D16Y5
Do you know anyone or have you seen any articles regarding engine swaps (i.e. B18C, D16Y8) for a D165? Mine has exceeded its predicted Mean-Time-Failure rate. I am using too much damn oil and I want a higher performing engine.
radicalrider is offline
Old 12-07-2003, 01:02 PM   #4 (permalink)
Cautela's Avatar
Re: D16Y5
Please keep it on topic, this is the wrong forum to ask that question but I'll help you anyway. Go to the HYBRID/JDM forum in here, it should have what you need to know about that. Here is a start:
Putting engine x in car y...
αθεος
Cautela is offline
Old 06-19-2005, 05:43 AM   #5 (permalink)
GreenLantern has a little shameless behaviour in the past
as a note to that if the rotor screw doesnt land in the right position turn key for one second then turn it off untill its in hte right position
Proud new owner of a 06 Galaxy grey Civic Si w/ Navi
So Fresh and so Clean Clean
GreenLantern is offline
Old 06-19-2005, 04:19 PM   #6 (permalink)
Cautela's Avatar
You can do that if you want but it'll take you hours to get it right... why do that when you could just break the rotor off? you're gonna replace it anyway. Another less simple way of doing this is by turning the crank until it lines up right but I don't recommend it.
αθεος
Cautela is offline
Old 07-10-2005, 08:00 PM   #7 (permalink)
Car: 97 Honda Prelude
Mods: Wings West Body kit, AEM cold air intake, DC Sports 4;2;1 Header, B&M shifter, 17" ENKEI wheels, KYB struts, Neuspeed Springs, Street Glow Underbody neons, Int. neons, 7" TV screen, PS2, Tenzo R Racing seats, Alpine CD player, 12" kicker subs etc.
lilhondaboy97 is an unknown quantity at this point
where can i find the internal distributor seal im having trouble. the seal that the shaft slides through?
lilhondaboy97 is offline
Old 07-11-2005, 09:02 PM   #8 (permalink)
expierence97's Avatar
Car: 99 Prelude Type SH, 83 RX7 GSL
expierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peonsexpierence97 Hello down there miniscule peons
I just replaced mine the other weekend. My screw was stripped so that was a major bitch, but other then that it's totally easy, pretty much self explanitory.
Audi A6
Yamaha R1
Prelude SH *RIP*
Mazda RX7 *SOLD*
Autocross is for drivers.
Drag racing is for cars.
Prelude FAQ
expierence97 is offline
Old 07-11-2005, 10:51 PM   #9 (permalink)
Black Hole
mad-ass's Avatar
Car: 95 S14
mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?
red X owns you. fix and i shill delete my post
edit: if you know where i am from...[OT SHO]
you'll learn not to do so
My S13/S14 Build Thread
mad-ass is offline
Old 07-11-2005, 11:05 PM   #10 (permalink)
If your'e inclined enough... on the Red X, right click, go to properties, then copy the url, past it into your address, and go. The picture should be there.
Audi A6
Yamaha R1
Prelude SH *RIP*
Mazda RX7 *SOLD*
Prelude FAQ
Old 09-28-2006, 09:51 PM   #11 (permalink)
tmak_ is an unknown quantity at this point
About the Rotor not being in the proper position, I got this tip from D-series.org
"If you cannot see the screw, feel for it and find out where it is. Put the car into gear and rock it back and forth. You will notice the rotor start to move. Do this until you see the screw. This is faster than turning the crank."
Anyone try this yet?
tmak_ is offline
Old 09-29-2006, 05:52 AM   #12 (permalink)
Cautela's Avatar
Damn that was a long time ago when SHO didn't have image hosting, so the pics are with imagestation, I haven't used imagestation in years and I'm surprised those pics still work...
On a side note, the pictures are working so STFU
αθεος
Cautela is offline
Old 09-29-2006, 05:55 AM   #13 (permalink)
Cautela's Avatar
Is it really that hard to just brake the old rotor off?
αθεος
Cautela is offline
Old 10-02-2006, 08:55 PM   #14 (permalink)
No but just wondering if it'll work
Anyhow I did try to move the car but the rotor didn't seem to spin at all, so I broke it off instead.. initially I didn't want to break anything for fear or something going wrong, but it was as ez as pie.
tmak_ is offline
Old 10-10-2006, 05:46 PM   #15 (permalink)
gnar_kill32's Avatar
Car: 1993 Honda del sol Si
gnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond reputegnar_kill32 has a reputation beyond repute
ive turned the rotor so i can get to the screw like 5 time in the past 2 days. its not difficult. but if you wanna take some stress out on the rotor for having to replace it go ahead. Turning the rotor only takes a few seconds either do it in short increments or have someone watch it for you. breaking it off is fine but i just want everyone to know that its not difficult to get the screw in the correct spot.
CarDomain Page
gnar_kill32 is offline
Powered by vBulletin®. Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
