Old 02-05-2005, 11:42 PM   #1 (permalink)
GunMetal Member
94Civic_R is a jewel in the rough94Civic_R is a jewel in the rough94Civic_R is a jewel in the rough94Civic_R is a jewel in the rough
DIY: EG Door Panel Insert Type R!!! Check it out! PICS!!
Well i decided to do a project so i figured i could do a write up since i appreciate ppl who do theirs! So heres goes nothing!
Well, what I did to my panels first of all i re covered the side panels in red for a more of a jdm/type r look! I think it looks awesome! to each his own tho!
First you will need some tools:
- Knife/scissors
- Adhesive spray (available @ any hardware store)
- Red tweed fabric about 1 yard by 1 yard!
- Lighter
- a friend (optional)
- about 4 hours of time
- Philips screwdriver
First off start off by taking your car panels off and bringing them to your workspace!
Then, what your going to need to do is melt the back pieces so that you can pop the plastic through! be careful you dont burn through the vinyl as it is very easy to do so!
After you do that, cut and measure out how much fabric you will be needing, its easier if you start from the top and work your way down to the easier spots therefore you have a little more play with the material so you can pull tight/adjust the fabric at the bottom!!
Once you have the surface covered and where you want it spray your adhesive on the surface you will be applying it too and also the fabric as this will make it a permanent glue! MAKE SURE YOU TAKE YOUR TIME AND DO IT RIGHT OR YOU WILL MESS UP! DO THIS SECTION BY SECTION! Do the corners and the hard areas very slowly therefore its eaiser to do since your working with a smaller amount of fabric!
Once you have your fabric lair all around cut out the holes for all the pockets such as the lower one, the pocket close to the door handle! Cut through the middle of this so you have enough to wrap you fabric around the edges this will help once your ready to reinstall the panel do the door panel!!
After you've done that, take a knife or something round and poke the holes out where the melted clips went and prepare the unit for reinstallment!
after youve poked those holes out this is where it becomes a little bit tricky, what you can do is either put the melted plastic back through the door panel and melt it back overtop which is very difficult or you can use screws and drive them through the melted plastic which is what i did! Much more stable and secure! It helps also if you wrap the fabric over and drive the screw through that also as it will be pulled even if the adhesive does come loose (which it shouldnt if done properly!)
Once youve completed these steps you should have something that looks like this!!
Good luck with your project and hopefully this will help out a few of you guys! Thanks for looking and keep it clean!!
- 94Civic_R (Jeff)
WTB: JDM EG6 Cluster! Lemme know if ur sellin'!
94Civic_R is offline
Old 02-06-2005, 12:31 AM   #2 (permalink)
gurusan's Avatar
Nice write up!
uɐsnɹnƃgurusan
Teal Civic Sold: 08/31/2006
FOLD FOR SHO! TEAM 54075
folding@home
gurusan is offline
Old 02-06-2005, 01:12 AM   #3 (permalink)
dmb
Premium Member
Speed with a Bazooka
dmb's Avatar
Car: Acura RSX Type S
dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?dmb you're still here?
nice nice nice that's unique honestly
dmb is offline
Old 02-06-2005, 09:13 AM   #4 (permalink)
SH Virus
riceboy89's Avatar
Car: 1998 honda civic
riceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapy
Nice job on the helpful write-up. Rep 4 U
DIY: bodykit foglight install
Originally Posted by hondatuner1320
youd be surprised how popular a lot of things are. the market for sleeper products is huge since most states treat you like a jew in 1943 poland if youre a ricer
riceboy89 is offline
Old 02-06-2005, 10:23 AM   #5 (permalink)
GunMetal Member
thanks guys. if theres one thing i cant stress enough is you need to take your time!
Old 02-06-2005, 01:28 PM   #6 (permalink)
projecthatch92's Avatar
Car: 92 Civic hatch
Mods: mad turbo boost
projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?
:w00t
projecthatch92 is offline
Old 02-06-2005, 01:35 PM   #7 (permalink)
GunMetal Member
Car: 2000 Si..It's blue damn it!
Mods: Almost stock?
SiNergy will become famous soon enoughSiNergy will become famous soon enough
I have been wanting to do the same thing to my interior. I am not a big fan of fuzzy arm rests. Nice write up!
SiNergy
SiNergy is offline
Old 02-06-2005, 02:28 PM   #8 (permalink)
Cypher Wave
.TheCriMson[K20]'s Avatar
Car: 97 Civic / 06 RSX-S
Mods: lotz
.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!.TheCriMson[K20] Bow down before me!
Good job man! easy to follow too
.TheCriMson[K20] is offline
Old 02-06-2005, 02:44 PM   #9 (permalink)
Car: '98 Civic Hatch DX
Mods: Carbon fiber hood, 15" Si rims with Kumho tires, 99-00 taillight conversion, DC Sports Lower Tie Bar, AEM Short Ram intake
hatchbackgirl is a jewel in the roughhatchbackgirl is a jewel in the roughhatchbackgirl is a jewel in the rough
Looks really nice... Good job on the write up!
hatchbackgirl is offline
Old 02-06-2005, 03:34 PM   #10 (permalink)
SH Virus
riceboy89's Avatar
im gonna try that on my 1996 Civic LX sedans door cloth. It looks atrocious right now.
Old 02-06-2005, 07:25 PM   #11 (permalink)
mulletov is a name known to allmulletov is a name known to allmulletov is a name known to allmulletov is a name known to allmulletov is a name known to allmulletov is a name known to all
That looks good as hell. Hey is your car in Canada an EX/Si? I notice u don't have power windows but u do have all the painted exterior trim and sunroof.
mulletov is offline
Old 02-06-2005, 08:31 PM   #12 (permalink)
jon
jon's Avatar
good write up, im gonna split this into the diy forum
silence is golden
but duct tape is silver
jon is offline
Old 02-06-2005, 10:43 PM   #13 (permalink)
mad-ass's Avatar
Car: 89 S13 Coupe, 95 S14
Mods: Over Drift gauge, Slide mode EFI, Smoke controller, Zip Tie meter, Cone G-force sensor
mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?
OMG OMG OMG!! Such a Quality work done! We all appreciate for those who post up our DIY's for the other people in such a detailed work. (even for myself, i posted up two, and I see that they have been to use, so I am happy and fulfilled my use for DIY section, wonder if I could be a DIY section mod/admin someday? wonders )
I will suggest to my friend with that busted up civic, and see what hes got to say.
Nice flawless write up nonetheless. Good work man!
mad-ass
mad-ass is offline
Old 02-07-2005, 02:40 PM   #14 (permalink)
GunMetal Member
Thanks a lot for the comments guys, i hope it gets to use! It does look really sick! i think im gunna try and get a full black interior tho, im either gunna paint it or try and piece one together! but we will see, i will try and post more DIY stuff in the future!
Old 02-07-2005, 03:14 PM   #15 (permalink)
Nyceguy17's Avatar
Car: 2000 Honda Civic Hatch DX
Mods: Type R goodies
Nyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputationNyceguy17 Among Gods/Goddesses in reputation
You need some red Tenzo R seats now! Nice, I will be trying this once I begin to work on my interior.
SHO Professional Theft Adv
