Old 09-18-2004, 05:51 AM   #1 (permalink)
DIY energy suspension mount insert with more details (56K warning)
Today, i decided to install the energy suspension with the OEM torque mount i have on my car. You have have seen my other post on this thread for DIY broken LCA bolt which i work with my friend, Phong. Please give me some credits if u are goin to pass this information to others becuase i have contribute more than 2-3 hrs on this. I work and took pics of myself cuz i thought it would help u guys who is goin to install the energy suspension. If u have any questions, please post on this thread because my PM box is always almost full.
I take no responsible for any injury that may have cause. Please know ur safety before u do it. I wear google all the time because when u are to remove the bolts under the cars, alot of rusts can fall toward ur eyes if u are workin directly under it. Good luck to you guys!
special thanks to team i n t e g r a.com for thier article. i have made this more details, so it'll be pretty much easier to see wat u should do in each step.
Let Begin:
The following tools and materials u'll need for this installation:
Google
Jacker, Jackers stand
Honda Steering Fluid
Extension pipe (for socket)
Socket wrench
10mm, 14mm, 17mm, 19 mm sockets
Phillip screw driver
Energy Suspension kits
Silicon Lubication spray can
Hayne manual book (you have to know wat u are doin before u actually doin it)
Here is the idea of those things u'll need.
Jack up ur car and remove tires on both side.
Remove the rubber thing that is under the car. use 10mm and phillip screw driver to remove that rubber thing.
On passenger side, remove the red bolts and loosen the blue bolts. Use the beaker pole with 17mm socket.
Use 19mm socket with beaker bar to remove that bolt of the torque mount.
Remove those two bolts. use 14mm socket with extension pole and beaker bar.
Take out that torque mount.
viet_83 is offline
Old 09-18-2004, 05:51 AM   #2 (permalink)
Insert new polyurethane energy suspension on it, but spray w/ silicon lubrication first to avoid squeakin sound when drive, then wrap them up as shown in pic.
Now put it back and do everything reverse, however, you have to use that picker tool to pull down the wrapper thing, so u can fully tight that 19mm bolt.
viet_83 is offline
Old 09-18-2004, 05:52 AM   #3 (permalink)
On the driver side, the way you remove the bolts of torque mount is the same way you did on the passenger side, but removin that torque mount of the driver side is very different than how u would remove on the passenger side. So pay attention cuz u'll need a honda power steering fluid for that reason.
Here is the pic of the torque mount of driver side:
After u remove the bolts, u can't really slide out that torque mount cuz it was block by that lil wall as shown in the pic.
So the way to slide out the torque mount is to unscrew the top motor mount so the motor would kinda fall down and allow you to slide that torque mount.
viet_83 is offline
Old 09-18-2004, 05:53 AM   #4 (permalink)
So first, place the oil catch pan under where the power steering fluid resevior is.
Here are the two places that u'll need to remove those bolts. U'll eed to use 14mm socket, extension bar, and socket wrench to remove those three bolts.
Now u'll need to unplug the power steering hose. so use 10mm socket wrench to remove those two bolts. Be careful cuz as soon as u remove it, the power steering fluid will start to come out and possible spray at u. It doesn't spray at me, but when i drop the motor down in order to remove that torque mount, it start to leak so that why you need the oil catch pan to gather those power steering fluid.
viet_83 is offline
Old 09-18-2004, 05:53 AM   #5 (permalink)
Now, lower the car to it angle. The motor should drop. But, if u can't get the motor to drop, u'll need to use a hammer to lightly pound those two bolts, so the motor will start to drop. dont pound too hard. I use the hammer because i dont want to waste my time and hopin that it'll drop itself. I lower the car first cuz i dont want it to fall down that high cuz who knows.
As u can see in the pic, the motor drop, so u can easily slide that torque mount out of it.
viet_83 is offline
Old 09-18-2004, 05:53 AM   #6 (permalink)
Same way as you insert the new energy suspension on that torque mount. Remember, lubricate it with silicon to prevent from squeakin sound.
Now put it back to where it's belong. Remember use the picker tool to pull the wrapper so the 19mm bolt can tighten up really well.
Now that u already have the motor drop, u can't really push them up haha. So u have to use two jack stand on the front to hold the car. use the jacker to push up the motor as shown in the pic, then screw the bolts back on the top motor mount and the power steering hose. Fill more honda power steering fluid to it max.
Now that u have the motor back in place, screw back two 17 mm bolts of the torque mount.
You're done. Now u have to put the rubber thing back on the car.
I hope all things work out for u. Again, if u have any questions, feel free to post on this thread. My PM box is always almost full. I will make some more DIY article on flywheel, clutch, turbo, and all sort of things that i want to put on my car.
viet_83 is offline
Old 09-19-2004, 12:53 AM   #7 (permalink)
Car: 95 Accord
Mods: nada
xxlilbuddhaxx is on a distinguished road
Great work man! Keep it up!
xxlilbuddhaxx is offline
Old 09-19-2004, 01:15 AM   #8 (permalink)
thank.. i got like 105 views and no comments.
viet_83 is offline
Old 09-21-2004, 12:23 PM   #9 (permalink)
Nguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphere
Great work Viet!
Nguyen is offline
Old 09-21-2004, 10:39 PM   #10 (permalink)
i can't install the rear mount insert on the GSR. damn intake manifold. i read the procedure on several sites, so i'll do it when i have alot of energy left in me. It's alot of pain to do it accordin to wat people say.
viet_83 is offline
Old 09-23-2004, 12:42 PM   #11 (permalink)
alrite i want to update my experience with this insert mount.
Pro: Transfer power to wheel than to motor, so it feel alot of quicker when stomp to the ground. even at launch
con: it vibrate alot on idle.. damn.. still annoyin so ull have to turn on the music to relieve that stress. It'll get worse if i tried to install the rear insert mount.
viet_83 is offline
Old 09-23-2004, 02:20 PM   #12 (permalink)
Car: 98 Civic CX
scottigee is a splendid one to beholdscottigee is a splendid one to beholdscottigee is a splendid one to beholdscottigee is a splendid one to beholdscottigee is a splendid one to beholdscottigee is a splendid one to beholdscottigee is a splendid one to behold
nice little photo documentary you have here...
I got to the same point on my mounts with a Prothane kit and stopped dead at the sight of the rear mount ... I don't think I'm going to touch that one either.
I'm scared to post a sig...
scottigee is offline
Old 09-23-2004, 02:38 PM   #13 (permalink)
hahaah imma do the rear insert mount someday. i know it'll vibrate even worse, but it's the price u pay for the performance.
viet_83 is offline
Old 11-09-2004, 01:40 AM   #14 (permalink)
Car: 93 Si
Mods: 93 Si w/ b16a3 swap w/ other goodies
outxider is an unknown quantity at this point
very informative. great job. i will be usin this post for my inserts soon.
R.I.P. The White 94 EX Coupe
BORN The Gunmetal 93 Si Hatch
EH3 powered by B16A3
outxider is offline
