Old 10-15-2007, 07:40 AM   #1 (permalink)
Iron Monk
d16y8alltheway's Avatar
Car: 1997 civic ex
Mods: i/h/e/ si tails/02 si wheels/high flow cat/type r headlights/mp3/wma player/
d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?
Thumbs up diy: honda keyless entry programming.
the following are instructions on how to program your remote transmitters for keyless entry.
i did this on a 2000 honda civic remote. the same procedure should work for the following:
-1998-2002 honda accord
-1999-2004 honda civic
-1997-2004 honda cr-v
-2003-2004 honda element
-1999-2004 honda odyssey.
these instructions may also be valid for other years and models.
these procedure clears the transmiters codes and creates new ones, so you must program all remotes at the same time, even if one or more is already working :
enter the car, and close the doors.
each of the steps must be completed within 5 seconds of completing the previous step. if you take longer or make a mistake, start the entire procedure over again.
insert the key in the ignition,and hold 1 remote in your left hand.whenever the instructions say press the lock button, you should press the lock button on the remote for about a second then release it.
perform each of the following 3 steps in order, then repeat all 3 steps 2 more times, for a total of 3 times each:
1.turn ignition switch to on position, marked II.
2.press the lock button.
3.turn the ignition switch to the accessory position marked I
next,turn the ignition switch to on position(II) for a 4th time.
press the lock button again. the doors locks should now make a cycling sound,indicating that the system has entered programming mode.
press the lock button 1 more time to program this remote.if you have other remotes to program,press the lock button on each one in turn. the door locks should make the cycling sound after you press lock on each remote. you may program up to 3 remotes, and they must all be programmed within 10 seconds of each other.
turn the ignition off and remove the key.the remotes are now programmed and may be tested.
if you got a trunk/hatch release button, hold the button for this function for a few seconds. and you re done!
psn born_2_race Click for PS3 Release Dates
d16y8alltheway is offline
Old 10-15-2007, 09:18 PM   #2 (permalink)
Premium Member
Eo, Mark Eo
markeo's Avatar
Car: 98 Civic LX
Mods: superhonda.com sticker
markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?
for 96-98 civics with the remote wired through the stereo:
1 turn the car on (not the ignition)
2 hold the valet button on the stock radio (between am/fm and cd i think) until the locks go
3 keep holding it
4 push a button on the remote
5 turn the car off
it should work, if not, make sure you held the valet button the whole time
Originally Posted by CBags04
google image search says thats was a good dream
4 Doors are the best!!
markeo is online now
Old 10-18-2007, 06:51 AM   #3 (permalink)
Iron Monk
Car: 1997 civic ex
Thumbs up
3 keep holding it
5 turn the car off
thanks for adding that.
Old 11-26-2007, 09:08 PM   #4 (permalink)
solkid's Avatar
solkid will become famous soon enoughsolkid will become famous soon enough
nice find man
buy my wheels
solkid is offline
Old 11-26-2007, 11:48 PM   #5 (permalink)
snailmonkey's Avatar
Car: 1996 Civic Coupe EX
Mods: DC Header, Carsound Cat, Apexi WS2 Exhaust, Edelbrock PerformerX IM, Modified Intake, Omnipower Street Full coilovers, Omnipower front and rear camber kits and LCA's, Kicker 6.5's in front with Punch 6x9's in rear, custom blacked-out headlights
snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!snailmonkey Um, 1 million? Damn!
2 hold the valet button on the stock radio (between am/fm and cd which looks like a plastic divider ) until the locks go
3 keep holding it
4 push a button on the remote and other remotes within 10 seconds, then release valet button
5 turn the car off and test the remotes
For whatever reason my keyless entry stopped working. I tried this method and it works! I've added some info to help others in the quote.
'96 Civic Coupe EX
snailmonkey is offline
Old 11-27-2007, 05:41 AM   #6 (permalink)
Premium Member
Eo, Mark Eo
markeo's Avatar
Car: 98 Civic LX
good work clearing that up, i dont know why i didnt include those parts in my original post
Old 03-31-2008, 09:06 AM   #7 (permalink)
Car: 2002 Honda Accord 2.3L VTEC LX 4dr.
Mods: Altezza Tail Lights, JDM Headlights, FUTURE changes: CAI, Ceramic headers, Exhaust System, 17" rims, bigger breaks, underbody effects(neons), goal headed: I want it to be a stylish car, not to race it. racing, I want other cars of mine to race, taht I dont spend money on looks for.
gregp08 You need a lifegregp08 You need a lifegregp08 You need a lifegregp08 You need a lifegregp08 You need a lifegregp08 You need a lifegregp08 You need a lifegregp08 You need a lifegregp08 You need a lifegregp08 You need a lifegregp08 You need a life
I got a remote from ebay, and the dealer says it isnt the right one. I got a 02 accord LX, does anyone know the right FCC for it?
gregp08 is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
