Theres really nothing to it. Just time.
Peice being used- 2001 Prelude center arm rest
Toolz needed:
1- Carbon fiber cloth (Ebay- $30 an up)
2- Fiber glass resin ($21 an up -Autozone)
3- Super glue( $1- Dollar store)
4- Cutting shears
5- some sort of scrapper (puddy knife)
6- some sort of cardboard to work on
7- Plastic dish
8- Krylon UV protected spray ($8+ shipping -Online)
First Get you Carbon fiber Cloth
Then cut about 2in bigger the then the piece your working with
Then Get your super glue and spread it over the top of the piece and lay the carbon fiber over the top. Make sure its flat and smooth when you do this. Also make sure you super glue the edge an any curves so it looks clean at the end.
Now that it is wrapped and pretty much stuck on there, get your resin
Mix it the way it says in to a plastic dish. Then dump a small amount in the middle of the object. Spread it evenly an slow motion(dont want bubbles) into the carbon. about 1hr before the resin cures an put another coat. If you do only one coat, you can still feel the carbon threw the resin.
now wait for itto cure. sand it smooth.
Dont sand it to the carbon fiber. If your a little wary about doing this, spray some clear to fill in the small bumps.,then sand, Repeat this process until it smooth.
Last step is to use some Krylon UV spray, only if dont use UV protect resin. Put a few coats of this spray an wet sand it in between so the resin wont yellow.
Thats pretty Much about it. I dont know if thats the "right way", but it works for me
