Old 12-29-2007, 10:04 PM   #1 (permalink)
Premium Member
Eo, Mark Eo
markeo's Avatar
Car: 98 Civic LX
Mods: superhonda.com sticker
markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?markeo you're still here?
DIY sidemarker install
i did this on my 98 civic, so the specifics are for that car, but other than that its basically the same process
step 1: remove front bumper. i can do this in my sleep and if you cant, this might be too much for you
step 2: remove screws/clips/bolts shown, i broke some of my clips, but the car went back together, so
step 3: take out screws/clips under car and slide side molding toward front of car to remove it
step 4: remove 3 bolts on top of fender under hood, 2 behind where the side molding was, and 1 behind the door, the door has to be fully open to get it out
step 5: i found these measurements from jdm universe, its about 5.5" and 6 1/8". then i drilled a hole at the center of where the tape crossed so i could line up my template on the back of the fender
step 6: line up the your template on the back of the fender centered on the hole, make sure its facing the right way too. i made my own template out of sheet metal, i cut out the basic shape, then gradually made more cuts to get the side marker to fit, and drew it on the tape i put on the fender. im not sure how much if any the tape helps, but it made me feel better, i taped both sides, and touched everything up with paint
step 7: basically the same way i made the template, i cut a smaller hole and gradually got it to the right size to ensure a good fit
step 8: tap into the existing signal wire, on my car (98 civic) its green/red wire for left and green/yellow for right, then just get enough wire to get to where the hole in the fender is, and probably secure it somehow, on this side i wound it around whatever that is in the pic, on the other side i used some zip ties
step 9: get a few of the bolts back on to hold the fender in place, i left the one behind the door out because i used that to ground the light, i just wound a bit of wire around the head of the bolt and tightened it in there. just make sure you are getting a good contact before you seal everything up by turning on the turn signal or 4-ways
step 10: put the rest of the bolts on to finish one side, repeat everything for the other side, put the bumper back on, drive in style
Originally Posted by CBags04
google image search says thats was a good dream
4 Doors are the best!!
markeo is offline
Old 12-29-2007, 10:12 PM   #2 (permalink)
Premium Member
Eo, Mark Eo
markeo's Avatar
Car: 98 Civic LX
oh, and im going to put a black silicone bead around it to seal it from water getting in there
markeo is offline
Old 12-30-2007, 03:17 AM   #3 (permalink)
Iron Monk
Meso Teggy's Avatar
Car: 99 Acura Integra GS-R
Mods: Short Ram Intake, MagnaFlow Cat, Greddy SP2 cat-back exhaust
Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?
nice write up y0
Meso Teggy is offline
Old 01-01-2008, 11:44 AM   #4 (permalink)
Frisbie217's Avatar
Car: 95 Ls/Vtec Integra
Frisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peonsFrisbie217 Hello down there miniscule peons
hey, nice write up im thinking about doing this to my teg, but how did you know how big to make the template?
lmk,
-josh
Frisbie217 is offline
Old 01-01-2008, 12:06 PM   #5 (permalink)
Premium Member
Eo, Mark Eo
markeo's Avatar
Car: 98 Civic LX
lmk,
-josh
i made my template kind of like trial and error, i knew the basic shape and some rough dimensions, and from there i just kept test fitting it and cutting slightly bigger any parts that didnt fit right
markeo is offline
Old 01-01-2008, 12:35 PM   #6 (permalink)
Frisbie217's Avatar
alright, so you just test fit the side marker into the template before actually cutting it into the car?
Old 01-01-2008, 12:53 PM   #7 (permalink)
Premium Member
Eo, Mark Eo
markeo's Avatar
Car: 98 Civic LX
right, i made sure the side marker fit in the template, then used the template to draw the shape on the fender so i knew how big to cut
markeo is offline
Old 01-09-2008, 10:40 PM   #8 (permalink)
Dark Wind
Car: 1994 Civic EX, 1998 Ranger
Mods: both stock
Anomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapy
wow you made that way more complicated than it should be YOU DO NOT NEED TO REMOVE SHIT TO DO THIS, all you need is a tape measure, a coat hanger and a unibit in a simple DRILL, you measure both sides, you drill both sides, and you use the coat hanger to pull the wires....you made about 3 hours of work out of 1 if anything you MAY need to pull the inner fender liner, but not the whole fender and bumper cover wtf were you thinking?? ive rewired reastaraunts, and houses, as well as cars, you deffenently made it harder than it has to be, maybe you just dont have the tools?? about the smartest thing you did was tape shit off so the paint didnt flake during cutting
Anomoly is offline
Old 01-10-2008, 05:17 AM   #9 (permalink)
Premium Member
Eo, Mark Eo
markeo's Avatar
Car: 98 Civic LX
i cut from the inside of the fender to not mess up the paint. yeah, i probably could have been fine doing it from the outside, but i didnt want to take any chances on it
markeo is offline
Old 01-10-2008, 10:38 PM   #10 (permalink)
Dark Wind
Mods: both stock
you took more of a chance by cutting inside than outside, if you used a rotary tool , you can rip the shit out of the paint by cutting inside to out, you can as well rip the shit out of it by cutting out to in....masking tape was smart, taking the whole car apart was not...........
Anomoly is offline
Old 01-16-2008, 04:01 PM   #11 (permalink)
CISCODC5's Avatar
Car: 2006 rsx-s
Mods: fujita cai
CISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peonsCISCODC5 Hello down there miniscule peons
nice and easy to follow have you done one for a rsx
my 06 dc5
CISCODC5 is offline
Old 01-17-2008, 07:44 AM   #12 (permalink)
Premium Member
Eo, Mark Eo
markeo's Avatar
Car: 98 Civic LX
no, i only did it on my civic, but i would imagine its the same basic process
markeo is offline
Old 03-30-2008, 05:07 PM   #13 (permalink)
soto2635 is on a distinguished road
nice write up
soto2635 is offline
Old 03-30-2008, 05:56 PM   #14 (permalink)
Frisbie217's Avatar
what did you use to cut it out with
