Old 04-19-2008, 05:38 PM   #1 (permalink)
dapallox1 is on a distinguished road
DIY Turbo Idea
Okay, this has been puzzling in my head for a while. I haven't gotten a chance to test it yet though. Lets say I put a 120psi air tank in my trunk with a a circuit that automatically turns on an air pump when the psi reaches, lets say, 50psi. A line comes from it to a regulator located next to the parking brake. Then to a electronic open/closed valve operated by a switch located on the steering wheel or any other place of convenience. From there, it is fed into the intake house very close to the engine its self. Since atmopheric pressure is at 14.7psi, you turn the regulator to around... 20 psi. When your engine reaches around 7k rpm, you hit the button. Would it have the same effect as a turbo?
I know that it wouldn't last long, but would it be like a "turbo-on-demand" thing?
dapallox1 is offline
Old 04-19-2008, 05:47 PM   #2 (permalink)
WVU97GS-R's Avatar
Car: 1989 240sx
NO!!!!!!. psi means nothing if you understood turbos. 15 psi off of a t25 is different than 15 psi off of a gt35r. your air pump i doubt would even approach the power of a real turbo.
http://www.superhonda.com/forum/f30/...please-333110/
Originally Posted by HonduhDave View Post
He's not Japanese, he was referring to the languages he can speak. He's capable of speaking English, can probably curse and ask for a beer in Spanish and has heard his girl moan in Japanese in bed
WVU97GS-R is offline
Old 04-19-2008, 10:13 PM   #3 (permalink)
ballahs-crew's Avatar
Car: 98 Accord V6
Mods: Rice... pssh SIKE!!!!
ballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these parts
it won't work. unless your airtank could literally blow a hole through your body, if it can't do that it won't work.
Haynes = Bible
ballahs-crew is offline
Old 04-19-2008, 11:13 PM   #4 (permalink)
Alrighty, thats all I needed to know. Thanks
Old 04-21-2008, 04:44 PM   #5 (permalink)
Car: 98 Accord V6
no problem
Haynes = Bible
Old 04-22-2008, 07:45 AM   #6 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
No, it won't have the same effect as a turbo, but it definately should provide a noticeable boost.
The Ford Lightning used a similar system where it stored cold air captured from the a/c system and when you floored it, it would dump it into the manifold.
The problem is that a compressor big enough to store a useful charge would weight enough that the performance boost might be lost due to the weight gain.
The idea of a stored compressed air charge is good, but actually implementing it would not be practical.
kommon_sense is offline
Old 05-26-2008, 10:50 AM   #7 (permalink)
StillAHondaFrea's Avatar
StillAHondaFrea StillAHondaFrea StillAHondaFrea StillAHondaFrea StillAHondaFrea StillAHondaFrea StillAHondaFrea StillAHondaFrea StillAHondaFrea StillAHondaFrea StillAHondaFrea
I rey don't mean to come off as a jerk, I mean this in the nicest way possible, but what made you think that would work, and how did you ever come up with that?
again, not hateing, just curious...
HONDA TILL I DIE!!!
StillAHondaFrea is offline
Old 05-27-2008, 12:17 AM   #8 (permalink)
Lifeless Ninja
TSM_Pikachu's Avatar
Car: 1995 Honda Accord Ex, 5 spd
TSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputationTSM_Pikachu Among Gods/Goddesses in reputation
Ideas from boredom or curiousity often give way to new innovation, this one however is a bust. lol
TSM_Pikachu is offline
Old 05-27-2008, 09:47 AM   #9 (permalink)
WVU97GS-R's Avatar
Car: 1989 240sx
so true. because of internet porn one-handed typing is now possible
Old 05-27-2008, 10:16 PM   #10 (permalink)
Dark Wind
Car: 1994 Civic EX, 1998 Ranger
Mods: both stock
Anomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapy
to clarify, the reason it wouldnt work, is because of FLOW RATE, not PSI, a standard 3/8 air hose just cant flow the CFM needed to produce boost in something that is sucking in air like crazy anyways
Anomoly is offline
Old 05-28-2008, 02:07 AM   #11 (permalink)
Talking
The funny thing is, you are all right... lmao
HONDA TILL I DIE!!!
Old 06-06-2008, 09:17 PM   #12 (permalink)
Dark Wind
Mods: both stock
back in highschool me and negrodamus hooked up a shop vac output to his intake, obviously we couldnt drive far, but it did rev alot faster....
Anomoly is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
