Old 09-30-2007, 01:44 PM   #1 (permalink)
Car: 2000 Civic EX
Mods: I/H/E JDM d15b vtec LOADS of suspension
speedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep troposphere
DIY: weekend paint job
ok well we all want to paint our cars for one reason or another, fix rust, that show car look, get rid of oxidation, bring a new life to your ride or even an attempt for a quick flip to make some cash off a car.
this is my virgin paint job so im probly as nervous as you are but fallow my steps and you will be FINE! first thing is remeber if you fuck up just sad and re shoot its time and some money but its not a big deal!
get all of you materials ready!! you will need roughly 300 dollars to do a decent paint job
your gonna need varius scuff pars and sand paper in varius grits from 400-1600 make sure its wet and dry
next up is some primer this one isnt very important just a quality name brand primer thats high build to fill in as much imperfection as it can
base coat, i like dupont readily available and pretty cheap, mine is of the flamenco black pearl verity know your paint code mine is nh592. also the proper reducer/activator you need as stated on the can
for the clear get the same company as your base is what I recommend, this is simply Duponts product from 6 months ago relabeled and sold for 1/2 as much haha. get the proper activator and if you are painting poly bumpers get a flex agent and use it ONLY in the clear
you will need buffing compounds to get that good shine! along with the recommended pads
for my project the only really bad part for me was the bumpers and front fenders the rest of the car can be fixed by buffing, so first step is to break the car down
remove anything you want to paint including any trim ect ect.
tehn start to sand down and scuff up all areas to be painted make it as smooth and flat as you can going up to about 600 grit or even more if you have time
Fill in any small pinholes or any other areas that are slightly warped with spot/glazzing putty or bondo, DO NOT USE OVER 1/8" thick , IMO even thats alot
I decided to smooth out the portion where my li joins the bumper to make it look one piece i used some epoxy for bumper repair it seems to have worked well, this is how it first looked
after filling everything with putty or bondo that needed it sand it smooth I went to 1400 wet sand before i hit it all with primer get it as smooth as you can
make sure to wash it down with soapy water, rinse with clean water, then wipe with a tack clutch to 100% get rid of all of the dust.
ow for the fun part begin to shoot some primer!!
primer is really hard to screw up and easy to fix so this is where you want to get your practice in!! my Friend Damir has painted many cars DIY style and he has decided to come over to help me he also brought over a few guns. gun choice isnt very important just keep them clean and in tight working order also use a filter in all of your lines
he has a HVLP gun along with the old school suction guns which work very well and are easy to keep stable in your hand. after the first coat of primer you will notice things much more! sand and use more putty as necessary then simply reshoot some primer its dry enough to sand in 30 min so fixes are quick
From there you simply let it all dry very well Im letting mine sit over night until the next session where we will be wetsanding the primer making sure its all 100% ready then we will shoot base/clear. little preview
MY VOUCHERS:
-Paypal:danijel_danicic@hotmail.com
-Ebay:dado03235
Originally Posted by riceboy89
nice setup man
(speedjunky01)your mom is so jdm!
CIVIC PRESSURE PLATE *CHEAP*
speedjunky01 is offline
Old 09-30-2007, 01:46 PM   #2 (permalink)
Cypher Wave
Randomhero's Avatar
Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?Randomhero you're still here?
awesome shit. dont know if i woulda done it outside though. but still good shit.
when i get my car hopefully soon. after the new year i wanna paint it flat blitz black.
so i figure, some friends some belt sanders, some coronas and bout 20 cans of paint and ill be good.
Randomhero is online now
Old 09-30-2007, 01:51 PM   #3 (permalink)
Car: 2000 Civic EX
i wouldnt do it with paint can flat black it absorbs moisture and traps it underneeth causing and accelerating rust. there is a flat black base/clear system out there I would go that route so it actualy protects your cars body
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 09-30-2007, 02:06 PM   #4 (permalink)
accordsleeper89's Avatar
Car: '01 Honda Accord LX 2.3, '90 Eagle Talon TSi AWD
Mods: Accord: SRI, EVO2 cat-back, and a few suprises....... Talon: 0-Broke in 3.2 secs
accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?accordsleeper89 you're still here?
very nice, I've considered reviving and trying to cover up a few holes in my fenders from when grandma went out on a joy ride
worst part is....she actually did it
This is all you will ever see:
accordsleeper89 is offline
Old 09-30-2007, 02:18 PM   #5 (permalink)
Car: 2000 Civic EX
do it man its not hard at all!!
my mom does burnouts when she barrows mine and she has driven it at 120mph lol
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 09-30-2007, 02:23 PM   #6 (permalink)
SH Virus
95integrars's Avatar
Car: 2005 Mazda 6i (i miss my teg :()
Mods: xxx
95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?
the clear coat is coming off my left fender. i need to do a touch up. is there a way to do it without having to repaint the whole fender?
| 2005 Mazda6 i |
Join the SHO group on Facebook
http://www.facebook.com/group.php?gid=2210247597
95integrars is offline
Old 09-30-2007, 02:27 PM   #7 (permalink)
Would it look alright if I buffed the rest of the car and only did the bumpers? or would I have to hit the rest of the car as well? because I buffed out the scratches in the fenders, but the bumpers need a little touch up......women can drive (in a basic sense of the word), but old women are a "no go"
Old 09-30-2007, 05:19 PM   #8 (permalink)
Car: 2000 Civic EX
it all depends how much clear is left. if its thick enough it will polish up nice. if there isnt enough left the paint will swirl or burn through and you will ned to paint it.
accord sleeper 89 thats exactly what im doing man
ill have it done in the next week or so ill post up some picture and you decide for your self. if it looks bad im just gonna do the rest of the car.
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 09-30-2007, 06:40 PM   #9 (permalink)
alright man, I'm subscribed, btw just call me Nick
Old 09-30-2007, 07:28 PM   #10 (permalink)
Car: 2000 Civic EX
k ill try and have it done by next monday cant do too much due to school during the week
Im dan BTW nice to meet you
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 09-30-2007, 07:34 PM   #11 (permalink)
yeah I hear ya on the school during the week thing, I don't even have my car in the same state, its just gathering dust except for the once a week drive it gets from a friend, so the earliest I'll get around to mine is Christmas maybe
Old 10-07-2007, 02:42 PM   #12 (permalink)
Car: 2000 Civic EX
i would have an update right now but the bluetooth on my comp stoped working cant upload pics
the paint is done and it turned out AMAZING i might have to do the rest of the car lol
ill try and get pics up ASAP
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 10-07-2007, 03:19 PM   #13 (permalink)
