Old 09-06-2004, 06:13 PM   #1 (permalink)
Car: 1991 honda accord LX
jimmy_petrichko is on a distinguished road
how to paint car interior?
i was painting my car interior and i did every thing right the next thing its chiping and scrashing up easly u used the vinal paint so isnt ther any way to do this better??
jimmy_petrichko is offline
Old 09-06-2004, 06:24 PM   #2 (permalink)
Car: 1996 Honda Civic Lx 4dr
Mods: too many to list...
toplevelej is a splendid one to beholdtoplevelej is a splendid one to beholdtoplevelej is a splendid one to beholdtoplevelej is a splendid one to beholdtoplevelej is a splendid one to beholdtoplevelej is a splendid one to beholdtoplevelej is a splendid one to beholdtoplevelej is a splendid one to behold
i acutally painted my dash to black.. it was grey.. i redid my interior black.. went to my local hardware store got me some "painters touch" paint "gloss".. got paint brush
1. cleaned service..
2. sanded down alittle bit..
3. cleanded again
4. applied one coat
5. let dry for about 1 hour
6. aplied second coat
thing shines so nice
ill try and get some pics
toplevelej is offline
Old 09-06-2004, 06:59 PM   #3 (permalink)
Car: 2001 Prelude
Mods: E55 Bi-Xenon Retrofit, AEM Intake, OBX Header, NGK Wires, DENSO Iridium Plugs, Blue Vacuum hoses, Exedy Organic Clutch, Fidanza Aluminum Flywheel, VIS OEM Carbon Fiber hood, All bulbs switched to white, Custom white painted interior and MOMO parts
snackpacks is a splendid one to beholdsnackpacks is a splendid one to beholdsnackpacks is a splendid one to beholdsnackpacks is a splendid one to beholdsnackpacks is a splendid one to beholdsnackpacks is a splendid one to beholdsnackpacks is a splendid one to behold
Best Interior Paint?
snackpacks is offline
Old 09-06-2004, 09:29 PM   #4 (permalink)
any more ideas?????
Old 09-12-2004, 09:59 AM   #5 (permalink)
04SiGuy is an unknown quantity at this point
not too sure bout this
i was gonna paint my dash but i saw alot of ones that were painted chip flake or rub off so i started to think what else to do my dad told me to make a new dash from fiberglass but that would take forever with the mold then pop out a dash but it would hold paint forever so i got a new idea 1st take out your dash then 2 use the above mentioned soap to remove the oils and shine 3 use some of the 3m super strong spray glue 4 stretch vinyl materal over the dash pull tight use a bondo squeegy to get out wrinkles 5 pull about 2in of vinyl around corners and edges and tack in place 6 use a heat gun to dry glue + form better & reinstall dash
dont know if it would work but if it did it would be better than paint and easer than fiberglass
tell me if you try it
04SiGuy is offline
Old 09-12-2004, 10:00 AM   #6 (permalink)
just an idea dont know if it will work sounds like it would
04SiGuy is offline
Old 09-12-2004, 09:57 PM   #7 (permalink)
40_Below's Avatar
Car: 1993 EH9 w/ D15b
Mods: Stock
40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile40_Below Needs to go outside once in awhile
Do a search in the autobody forum.
40_Below
40_Below is offline
Old 09-13-2004, 04:25 PM   #8 (permalink)
justed tryed automovtive paint so it works better thanks for the help any ways :clap
Old 10-07-2004, 05:47 PM   #9 (permalink)
Car: 94' Civic
Mods: Soon to be sporting a H22
djvillar is an unknown quantity at this point
I did my interior for the second time this summer. The first time I did it I put the coats on too thick. If you put it on too thickm, the paint will dry, but it will always have a sticky feel to it.
Painting the interior is not hard at all, but BE PATIENT. Its not easy to have to do it all again.
Also, don't think that you have to cover it in two coats. You'd much rather do 10 light (very light) coats that dry well then the other way around. And remember its takes a while to tape and prep everything. If you do all the work to prep the space, you have it that way until you decide to take it off... so use it. Don't try to rush the job. Preping again sucks.
94' Civic lx
Sound System:
Pioneer deh-p9600
4x 3-way pioneer
2x Audiobahn 10" High Excursion Sub
2x Audiobahn A8000T Mono Amp
Good $hit to know:
http://web.njit.edu/~cas1383/proj/main/
4 Doors are the best!!
djvillar is offline
Old 10-07-2004, 05:48 PM   #10 (permalink)
Car: 94' Civic
If you take your time... it will be real pruddy.
94' Civic lx
Sound System:
Pioneer deh-p9600
4x 3-way pioneer
Good $hit to know:
djvillar is offline
Old 10-14-2004, 09:00 AM   #11 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
one thing to keep in mind when painting the interior. A lot of people like to paint the dash white or some other bright color. Light colors will reflect sunlight and trying to drive with a white dash is near blinding.
kommon_sense is offline
Old 10-15-2004, 10:30 PM   #12 (permalink)
Car: 1997 Civic JDM B16a
Mods: H&R Springs, Short Shifter, CAI, Magnaflow exhaust, Iridium Plugs, NGK Wires, GSR Computer, Wheels, Power-adding Blue Engine Paint
JDMikey will become famous soon enough
well, if you plan to paint it yellow or red, first you take some low-gloss paint and mix it 3 parts to every one part soy sauce to match it work well with the rest of the rice that must be everywhere else on the car
jokin, I've actually thought of redoing my stuff, my buddy used the dye to do every panel is his old vette and it looked GREAT....cept it seems like our dashes are rubber/plastic and I dunno how it would dye
JDMikey is offline
Old 10-26-2004, 09:49 PM   #13 (permalink)
Car: 1995 Prelude
Mods: JDM H22A Swap, Other small mods. More in the future.
PreludeKing1995 has a spectacular aura aboutPreludeKing1995 has a spectacular aura aboutPreludeKing1995 has a spectacular aura about
how would you paint over the prelude door panels, 4th gens have vented leather peices on the door??? would it stick to it?
Click To See My Prelude!!!
Ahhh Preludes, the heavy ass beauty of the Honda family... Gotta love the ass of the 4th gen... POW!!!
PreludeKing1995 is offline
Old 11-09-2004, 07:07 PM   #14 (permalink)
SH Virus
riceboy89's Avatar
Car: 1998 honda civic
riceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapyriceboy89 needs rep therapy
3. cleanded again
4. applied one coat
can you post some picts??
DIY: bodykit foglight install
Originally Posted by hondatuner1320
youd be surprised how popular a lot of things are. the market for sleeper products is huge since most states treat you like a jew in 1943 poland if youre a ricer
riceboy89 is offline
