Old 09-09-2007, 09:04 PM   #1 (permalink)
Juggles is an unknown quantity at this point
Vibrating Short Shifter Solutions?
I have a B&M short shifter with a knock-off Type-R shift knob (pretty heavy). At highway cruising speed, though, the whole stick vibrates. It's not bad, but I like a quiet car. Has anyone dealt with this before and fixed it? Maybe a bushing or something that would absorb the vibration from the transmission is available? Thanks for any info.
Juggles is offline
Old 09-10-2007, 01:59 AM   #2 (permalink)
SH Virus
95integrars's Avatar
Car: 2005 Mazda 6i (i miss my teg :()
Mods: xxx
95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?
when my short shifter was loose it was because the bushings had cracked. i removed the shift linkage and replaced the broken bushing and now everything's fine. that's probably what you're gonna have to do.
| 2005 Mazda6 i |
Join the SHO group on Facebook
http://www.facebook.com/group.php?gid=2210247597
95integrars is offline
Old 09-10-2007, 03:41 AM   #3 (permalink)
Black Hole
ATISTANG's Avatar
Car: 79 Yugo
does it have a bunch of play in it?
is it a adjustable shifter? the shorter the throw the lower the shifter will stick out from under the car, it might be rubbing the exhaust
ATISTANG is offline
Old 10-19-2007, 08:31 PM   #4 (permalink)
96exboy is an unknown quantity at this point
i got the same prob and i already tried new bushings any one have a clue how to fix it i also have a b&m
96exboy is offline
Old 10-21-2007, 06:55 PM   #5 (permalink)
Dark Wind
Car: 1994 Civic EX, 1998 Ranger
Mods: both stock
Anomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapyAnomoly needs rep therapy
i have no experience with BM shifters, but it sounds like they are pretty sloppy on their manufacturing tolerences on this shifter, it sounds like the shifter just does not seat well in the honda linkage or it may be touching the exhaust, for a shifter to vibrate enough to piss you off something is not right, obviously they will vibrate but at highway speeds and RPM it should only be minor like a cell phone vibration but a little less, this is an effect of motors being balanced
Anomoly is offline
Old 10-22-2007, 07:36 AM   #6 (permalink)
It's a short throw without much play in it and it's not touching the exhaust. It just picks up the vibrations from the transmission.
Juggles is offline
Old 10-24-2007, 07:53 PM   #7 (permalink)
yeah it was man but got it fixed today i just took and bent the hanger down a little bit and fixed the prob right up
96exboy is offline
Old 10-25-2007, 11:45 AM   #8 (permalink)
hampsterpower is on a distinguished road
easy fix
I was bugged by this problem for months before I found a fix.
B&M ships with soft black rubber O-rings as dampeners(inside shifter to linkage joint) find similar sized hard O-rings in the plumbing department at the hardware store. There were four rings on mine. I replaced all for a few bucks.
It will be a tight fit, but no more BUZZZZZ!
I did this a year ago. so far so good.
I feed the hamster NOS, he went to sleep.
now I give it a Clifbar instead.
hampsterpower is offline
Old 10-25-2007, 12:29 PM   #9 (permalink)
instant_classic is on a distinguished road
I had the same problem and it drove me nuts. More specificially it occured at about 3000 rpm all the time.
I bought energy suspension shifter bushings and a fidanza short throw. I put some threadlocker red on all the screws and nuts, then tightened everything down HARD.
No more buzz, no more play, nice crisp shifts, very happy, just tighten the shit out of it and you should be fine, just don't tigthen it your shifter too hard or you won't be able to shift lol.
Good luck!
1997 Civic DX, Weapon R short ram intake, Weapon R ram air kit, Thermo-Tec heat wraping, 2 1/4 CB exhaust (Pacesetter), Autometer Tach, VDO Oil press/Volt gauges, Fidanza short throw shifter
Originally Posted by Lie_Cheat_Steal
but its jdm, it must work
Originally Posted by ATISTANG
yes but you have to covert the fuel lines to right side flow
instant_classic is offline
Old 11-02-2007, 01:09 PM   #10 (permalink)
BLUEB16 is an unknown quantity at this point
i had the same problem. i bought some stock bushings for the shifter not thinking. since i couldnt use the new bushings, i put a split ring lock washer on either side of the linkage and tightened the crap out of it. now i have no more noise and the shift is now a lot more firm and smooth.
BLUEB16 is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
