Car: 99 Civic Si
Mods: LS-VTEC W/Power Steering & Cruise Control,Mild Built Head,AEM Fuel rails,AEM Fuel Pressure Reg,CTR Pistons,Adj. Cam Gears,AEM CAI,JDM Full Race Headers,3Bros. Race Clutch,Type R Flywheel, Eibach Lowering Springs,KYB GR2,HanKook GR2,Drag DR20 Shoes,Tanabe Medallion Exhaust,2 Inch Piping,Black Housing Headlights W/ Yellow HID, Sony XPLODE indash
99 Civic Si 7,400
Salvaged (airbags where removed when stolen and given a salvage title , as far as i know the car was not hit or involved in any accidents)
Car has both airbags
68,000 original miles
LS VTEC SWAP (Integra block w/ B16 head 1.8 Type R internals, poormans Type R) Mildly Built Head
Less than 3,000 miles on the motor
New brake master cylinder (Installed @ Southgate Auto)
New Clutch master cylinder (Installed @ Southgate Auto)
New clutch slave (Installed @ Southgate Auto)
New fuel filter (Installed @ Southgate Auto)
Power steering
Viper Alarm (Keyless entry)
Manuel Killswitch
Drill and slotted front rotors
Current 08 tags
Blacked out headlights
Type R Grill w/ Si badge
Integra Type R, headers, valvesprings, retainers, pistons, ecu (Erick's Racing)
STR Adj. cam gears and STR fuel rails
B16 Tranny (short fast gears no grinds)
AEM short ram intake w/ new style AEM dry filter
NGK wires and plugs
Royal Purple Syn.
GSR Shifter
OEM front strut bar and OEM lower rear sway bar.
Clean and complete interior (non smoker)
Power doorlocks, windows, sunroof , mirrors, heater and defroster.
Exterior is in good condition
Polished 15x7 drag wheels w/ Hankook Ventus Rs2 tires 85 % thread left , with black tuner nuts and lock
Lowered on H&R springs (red)
Stock shocks
Stock exhaust
Bigger straight piping (no cat or res.) with flex pipe from the headers back to avoid cracking or breaking the headers
VTEC @ 6000, powerband up to 8000 can rev safely to 8500, needs rods to go past 8500 safely.
Runs strong and hard, needs but not required- Hondata, bigger injectors , bigger throttle body and tuning to run at its full potential. Motor is an 11 sec motor in an EG or CRX, The motor was put together by InLine Four in Gardena, the internal work was done at Southgate Auto Electric by George.
"Friends Don't Let Friends Buy Altezza Lights"
