1993 Eagle Talon TSi AWD 5spd 2.0 DOHC TURBO. It has a bone stock early 92 6bolt motor in it with around 103k miles. For reference, late 92-94 DSM's came with the weaker 7bolt motors. Ive owned this car for about 3-4 years. Im the 3rd owner, original owner bought this car new in california. I wasnt really looking for a talon, i was in search for a plymouth laser, but this one was for sale locally and it was in immaculate condition. Since the day i bought it, it was always garage kept and covered. The stock 7bolt motor wasnt in %100 condition so i swapped in a nice 6bolt motor from a early 92 talon awd. I didnt feel comfortable dumping money into modifications cause i really wanted a laser, so i just did regualer OEM maintence.... which includes, timing belt, balance shaft belt, all 3 tensioners, idler pulley, waterpump, all front case oil seals, oil pan gasket, rear main seal, clutch disc, pressure plate, release bearing, transmission axle seals, all upper engine gaskets(head, valvecover, intake, PCV, ARP headstuds, etc), fuel filter, coolant flushed, K@N filter, magnacore wires, oil always changed with mobil 1 and factory filter.... i know these cars pretty well so i knocked out all the major maintence out of the way. Work done by EXPERIENCED technician. Since its a 93 it has the bigger 2 piston calipers, bigger rotors, LSD rear end, also has ABS, tan leather, am/fm cassette, p/locks, p/steering, AC, heat, etc. Has all options except CD and sunroof for this model. %100 stock with exception of ARP headstuds and K@N filter. Car is in really good shape since its from california. No rust or corrosion. Engine bay looks brand new. Most of the bolts and brackets have that factory gold look. Car has never been wrecked and has a clean carfax report.
Imperfections i find in the car... exterior body is in great shape, paint is factory and has no fades or paintwork. Theres a small scuff on the corner of front bumper. Drivers front fender has a small ding in it. Theres a 4 inch scratch on passenger rear quarter panel. Interior... drivers seat has some wear on the side(no tears). Lastly, theres a slight exhaust leak coming from the flex section of the downpipe. Its VERY quiet so i left it alone cause you can hardly hear it. Besides that, car is in great shape. Should ace inspection. Everything works. This is one of the cleanest DSM's out there. Im asking 5000 firm. Located in rockville MD. cell # 2403725805
