Im selling my 93 black Honda Civic Ex coupe:
B16a2 from a 2000 Si with about 80k miles, body has 209,xxx miles on it
Grey/black cloth interior
skunk2 intake manifold, with come with stock IM also
oil pan has bung for oil return (was turbo at one time) bung is capped off, will come with stock oil pan also...
cheap header
cheap cold air intake
apexi mid pipe
99-00 Si axle back (not installed, wouldn't fit), will put cheap axle back before selling...
Stage 2 clutchmaster clutch
aftermarket fuel rail will come with stock fuel rail drilled for Nitrous
b & m fuel pressure regulator
msd external coil blaster ss
stock flywheel
short shifter
older pioneer cd player, newer speakers all around, but no tweeters, car is also wired for subs...
gsr rear lca
gsr rear sway bar
new kyb agx 4 way adjustable struts
omni power sleeve coilovers... 10k front, 8k rear
smoked tail lights
will come with steelies with good tread
will come with 2 front bumpers
has the usually honda cancer on both rear corner panels
paint is pretty much gone... its faded, peeling
CEL o2 sensor primary
Located in Rockford, IL
These are old pics but it looks all the same expect all the turbo parts are gone, and the wheels and tires are also gone...
haters need not comment...
3500 obo
NO REASONABLE OFFER WILL BE REFUSED
