Street/Drag Acura Integra (650hp Daily Driver)
The motor is out of the car.
PLEASE CALL 949-280-4341 for questions. 95 ACURA INTEGRA WITH CUSTOM BMW LEMANS BLUE PAINT JOB BY MOB WORKS. CUSTOM 8 POINT ROLL CAGE DONE BY GARY AND JENSON WITH SWING OUT BAR ON DRIVER SIDE. CUSTOM MOUNTED FUEL CELL IN HATCH. BRAND NEW FROND END: HEALIGHTS FRONT AND REAR BUMPERS, OEM TYPE-R LIP, SIDE SKIRTS, AND REAR SKIRTS. APEXi N1 DAMPER COILOVERS. THE MOTOR IS A fully built b16 head/b18 block rated at 650 hp off race gas and 850 hp off of methonal. i have a list of all parts purchased from DYNAMIC AUTOSPORTS. two GSR transmissions. Twin SX engineering fuel pumps and fuel filters. the value of motor, alone is $20,000. the following is only some of the parts on the motor... MOTOR BUILT, ASSEMBLED AND BLUEPRINTED BY NAOTO NEGISHI OF BLAST RACING Ferrea valves (in & ex) 0.5mm re-surfaced, cleaned, and ported head with new valve guides , valve seals, and valve job all new springs toda cam gear set toda cams b-spec (in & ex) str throttle body (lock tight) Custom JG edlebrock intake manifold with custom secondary fuel rail crower retainer (set) JE piston ring set 81.00mm high tension .827 wristpin w/locks ARP head studs Darton sleeves 81.00 mm pre-cut upper & lower gasket set Moroso Oil Pan and oil pickup water pump new bearings oil pump peak rods - pro series MAX hp peak main stud Embee: high performance Hi - Temp Piston coating and dry lube skirt coating aebs primary and secondary fuel rails and much much more... Dave 949-280-4341.
reply for pricing, pics, and details
or call 949-280-4341
