turbo crx built motor 400whp
i have a 89 turbo crx for sell. everything has around 3000 miles on it. no leaks and dont smoke one bit.
here is the list of the motor parts:
lsvtec motor B18a
bore work and crank turned when built
81.5mm wisco pistons
eagle rods
block gaurd
jge tit. retainers,
springs,
and ss valves
mild ported head
ported intake manifold and throttle body
880cc injectors,fuel rail, walbro 255 pump
garrett 60-1 turbo
custom exh.manifold,
3in. down pipe, dump tube
tial38mm wastgate
11x31x3 intercooler
manuel boost controller
autometer air fuel,boost,oil gauges
hondata s100
on the dyno it did 401whp
@17lbs of boost at 8200 rpms
shaved door handles, full roll cage, 4 point harness, 6 puck ACT clutch, lighten flywheel, ect...
also have a extra set of wheels 16x7
i am needing to sell for personal reasons
price is $5500 obo
car located in TX
