yOparts new Catalog has just been upgraded and we are excited to offer Boomslang you will find there entire product lineup right
HERE!!!
Boomslang Factory Extension Harness
*BoomSlang Fabrications Factory Extension Harness* * Don't damage your Stock Harness! * Get some extra room to solder into your factory harness. * With a Boomslang Factory Extension - your op...
Boomslang OBD Conversion Harnesses
*Boomslang Fabrications OBD Conversion Harness* * OBD2 to OBD1 * OBD0 to OBD1 * OBD2 to OBD2A/B * OBD1 to OBD2 * For OBD0 to OBD1 You will need also need a 4-wire oxygen sensor and OBD1 ...
Boomslang Plug n Play Harness - AEM F/IC
*Boomslang Fabrications AEM F/IC Harness* * Boomslang supplies the AEM F/IC sub-harnesses. No cores required. * Fully plug and play. * Saves time, money, and your factory wire harness. * Fo...
Boomslang Plug n Play Harness - APEXi AFC Neo
*Boomslang Fabrications APEXi AFC NEO Harness* * Save yourself from a headache, use a Boomslang AFC NEO PnP harness! * Boomslang supplies the AFC NEO sub-harnesses. No core required. * Fully ...
Boomslang Plug n Play Harness - APEXi SAFC
*Boomslang Fabrications APEXi SAFC Harness* * Save yourself from a headache, use one a Boomslang SAFC PnP harnesses! * Boomslang supplies the SAFC sub-harnesses. No core required! * Fully plu...
Boomslang Plug n Play Harness - APEXi SAFC 2
*Boomslang Fabrications APEXi SAFC 2 Harness* * Save yourself from a headache, use one a Boomslang SAFC 2 PnP harnesses! * Boomslang supplies the SAFC 2 sub-harnesses. No core required! * Full...
Boomslang Plug n Play Harness - APEXi VAFC
*Boomslang Fabrications APEXi VAFC Harness* * Save yourself from a headache, use one a Boomslang VAFC 2 PnP harnesses! * Boomslang supplies the VAFC sub-harnesses. No core required! *...
Boomslang Plug n Play Harness - APEXi VAFC 2
*Boomslang Fabrications APEXi VAFC 2 Harness* * Save yourself from a headache, use one a Boomslang VAFC 2 PnP harnesses! * Boomslang supplies the VAFC 2 sub-harnesses. No core required! ...
Boomslang Plug n Play Harness - GReddy e-Manage
*Boomslang Fabrications GReddy e-Manage Harness* * Save yourself from a headache, use a Boomslang e-Manage PnP harnesses! * Boomslang Supplies the e-Manage sub-harnesses. No core required! * ...
Boomslang Plug n Play Harness - GReddy e-Manage Ultimate
*Boomslang Fabrications GReddy e-Manage Ultimate Harness* * Save yourself from a headache, use a Boomslang of our e-Manage PnP harnesses! * Boomslang supplies the e-Manage sub-harnesses. No cor...
