Gizzmo CamFC Cam/Fuel Controller VTEC/MIVEC
When performance accessories are fitted to your vehicle (cams, exhausts, air filters etc) the engines management system goes out of tune. This is often recognized by not getting the power gains that you anticipated when these accessories were fitted. By fitting a
CamFC, your vehicle's air/fuel ratios can be modified to suit your performance accessories resulting in an increase in Power, Torque, Response and economy.
The cam switching function of the
CamFC allows you to optimize your cam switching point to suit your modifications, further enhancing mid range Power and removing holes in the power curve.
For non-adjustable cam vehicles, the
CamFC can be used for its AFC and Tachometer features while the cam trigger output can be used as an RPM switch for a shiftlight, high boost solenoid, NOS etc.
- Onboard VTEC/Mivec Controller
- Real-Time Digital Tachometer
- High Speed RISC Processor
- Supplied with all accessories
- Aluminum Casing
- Dot Matrix display
Gizzmo CamFC Fuel / Cam Controller VTEC/MIVEC Instruction Manual
For Dealer & Distributor Pricing: Contact GizzmoUSA
