The
Gizzmo Thermal Gasket is a thick 'Phenolic' inlet manifold gasket that acts as a barrier stopping heat transferring from the engine block through into the inlet manifold. Stopping this heat transfer results in a cooler inlet charge temperature and in doing so increases engine power in much the same way an intercooler does, except this is able to benefit a turbo and non-turbo setup.
Key benefits of using the Gizzmo Phenolic Thermal Intake Gasket:- Produces a cooler intake manifold and intake charge resulting in MORE POWER
- Almost invisible modification, looks stock for the stealth factor
- Better gas mileage
- Replaces stock gaskets
- Reusable over and over
- No undesirable side effects
