you cant just plug n play dsm 450 injectors. they are wayyyyy oversized. they must be dynotuned.
think of a gardenhose. when your thumb is over the tip and it is trickling, the water sprays out in a fine mist. then when you turn the water up and remove your thumb, it just pours out. this is what is happening in your car when you compare stock VS 450 injectors.
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
