ecu swap...
i had a EDM Del Sol with a D16Z6 engine with an Auto transmission... the ecu is a P28... i plan to swap the transmission to manual.. i had a JDM P06 ecu and transmission from a D15B... will the JDM ecu compactible with my EDM engine?? Wat else do i need to complete the swap provided i had the clutch pedal, shift linkage, shifter and others if i've left out??
