Go Back   Honda Forum / Acura Forum - SuperHonda.com > Performance - Tech > ECU & Fuel System
Old 03-11-2008, 04:50 PM   #1 (permalink)
Car: 2000 Civic SI
Mods: Lowered 2", Greddy Exhaust
DoubleOcivicSI is on a distinguished road
Testing Ecu
Is there a way to do this? Need to find out if it is bad or not.
Sold: 97 Civic Coupe EX
Current: 2000 Civic Coupe SI (under construction)
Email:truwestsida@yahoo.com
Don't put your car's security in another's hands:http://causeforalarm.thecarthing.com...on6/index.html
DoubleOcivicSI is offline
Old 03-13-2008, 06:51 AM   #2 (permalink)
CapnToll's Avatar
Car: 1996 Integra SE
Mods: See the sig.
Can you be a bit more specific? What do you mean by your ECU being "bad?" Is something going on with your car making you think the ECU is the problem?
1996 Acura Integra SE
Motor: BC0022 Cams, Crower V/T, AEM Cam Gears, Comptech Icebox, Skunk2 I/M w/ Hondata gasket, DC-S 4-2-1 Header, 2.07" Brullen Cat-Back, B&M FPR, FAL Rad/AC Fans.
Tuning: UBERDATA, FJO Racing Wideband AFR System/Gauge
Security: Computer chip ignition Immobilizer, Intrusion alarm, Glass break alarm, and of course... THE BAR!!
Old Dyno: 175whp @ 7500 RPM / 135wtq @ 7000 RPM........ERTW
2001 Toyota Highlander V6 4WD - Winter Car - 220bhp / 222tq Bone Stock Baby!
CapnToll is online now
Old 04-03-2008, 10:08 PM   #3 (permalink)
CheezeNip-NSX's Avatar
Car: 1992 NSX
CheezeNip-NSX is on a distinguished road
How about the red light on the ecu stays on all the time. No spark but the engine turns, cant hear the fuel pump turn on either
CheezeNip-NSX is offline
Old 04-04-2008, 04:37 AM   #4 (permalink)
CapnToll's Avatar
Mods: See the sig.
Check your Main Relay. Most likely a pin on the main relay got loose and needs to be re-soldered.
Old 04-04-2008, 12:47 PM   #5 (permalink)
Car: 1992 NSX
already checked i even changed it out with another one but same thing
Old 04-04-2008, 03:59 PM   #6 (permalink)
CapnToll's Avatar
Mods: See the sig.
Check all your fuses? Is this your NSX or something else?
Old 04-04-2008, 05:50 PM   #7 (permalink)
Car: 1992 NSX
its on my 89 crx si
Old 04-04-2008, 06:11 PM   #8 (permalink)
CapnToll's Avatar
Mods: See the sig.
Originally Posted by CheezeNip-NSX View Post
its on my 89 crx si
Not my area of specialty, but if it's like the 90s Civs and Tegs, then you should have the fuses by the driver's left knee, and under the hood. Should be electrical if your Fuel Pump isn't priming. If you have a CEL or the ECU is blinking to indicate a CEL, you should get it scanned or read it yourself.
Old 04-05-2008, 12:36 PM   #9 (permalink)
Car: 1992 NSX
No reading on the ecu the light comes on and stays one all the time. when i crank it the engine light does'nt come on, does that mean my ecu is bad.
Old 04-05-2008, 03:44 PM   #10 (permalink)
CapnToll's Avatar
Mods: See the sig.
I wouldn't know what any light sequences would mean on your ECU. Try to search it up, or just go get your ECU scanned. If it is able to scan, and has no codes, you can narrow down the problem. If it can't be scanned at all, you'd know there is something wrong with the ECU.
But you most likely have an electronics problem...from bad main relay to a short somewhere. And you already said your main relay is fine.
Old 04-05-2008, 04:06 PM   #11 (permalink)
Cypher Wave
Mods: h23vtec
98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy
you need to test your main relay wiring.
the main relay controls the fuel pump. If there is a break in the harness somewhere, you could keep replacing main relays and still never fix the problem.
Check your fuses. there is a fuel pump fuse (should be atleast) on the in cabin fuse box.
98vtec is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
