My question is about the fast idle air controller. I bought an aftermarket edelbrock throttle body. As you can see it comes with a plate on the bottom. On the stock tb there is a fast idle air controller connected at the same spot. Because this plate is provided with the edelbrock one it leads me to believe that you can possibly run the setup without the fast idle air controller. Is there any harm running without the fast idle air controller or is it necessary to run my setup with one? My setup is a boosted setup with a GT30r. Thanks.
