There aren't any wiring harnesses available for the L15 ECU as of yet (either extensions or p&p solutions), and I didn't feel like shelling out the coin for a custom piece. My kit came with color-coded scans from the helms manual cross-referenced with the wiring harness guide in the E-Manage manual (with corrections made -- keep reading).
That said, it was still a pain in the a$$. The E-Manage manual is actually WRONG (!!) on a number of the wire colors.
BTW, the harness IS a genuine Greddy unit.
Overall I'm happy with my tuning setup, as short of a complete ECU swap complete w/ custom tune it's the best solution available ATM. The Ultimate is much, MUCH more capable than the E-Manage classic (blue), and since I'm not trying to alter the AFRs in closed loop (off-boost), the stock ECU isn't fighting me for control (save for part-throttle boost situations, where it still aims for 14.7 -- these situations are usually very short-lived and I avoid them by staying out of boost unless I'm ready for full throttle).
The only complaint I had about the whole kit was the Greddy manual's wiring harness. It's pretty obvious where it's wrong. For example, in both ignition and injection pulses each cylinder has a color (red, blue, orange, etc), and a colored stripe indicating input/output. However, the CH4 injection circuit is labelled as PINK (which is actually CH5).
Once it was wired in correctly and running full intercept on MAP, fuel and ign (tps, rpm are monitored), all is running well, and changes made in the EMU are very effective at moving my fuel trims and boost AFRs.
